<!– Class –> This is the event arguments class for the LayerDrawing event on the MapEngine class. It is raised before the layer is drawn.
This is the event arguments class for the LayerDrawing event on the MapEngine class. It is raised before the layer is drawn. This event allows you to cancel, manipulate the Layer, or draw something with the canvas before the Layer draws.
*System.Object System.EventArgs *ThinkGeo.MapSuite.Core.LayerDrawingEventArgs
LayerDrawingEventArgs | This is a constructor for the class. | ||
LayerDrawingEventArgs | Layer, RectangleShape, Object | This is a constructor for the class. |
Cancel | Boolean | This property gets and sets the value that indicates you want to cancel the layer from drawing. | |
CurrentLayer | Layer | This property gets and sets current layer that will be drawn. | |
NativeImage | Object | This property gets and sets the GeoImage or native image that we are drawing on. | |
WorldExtent | RectangleShape | This property gets and sets the world extent that will be drawn. |
This constructor allows you to set the Layer to be drawn, the world extent, and the image you are drawing on.
| currentLayer | Layer<!– ThinkGeo.MapSuite.Core.Layer –> | This parameter is the layer you will be drawing. |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the world extent you are drawing. |
| nativeImage | Object<!– System.Object –> | This parameter is the GeoImage or native map image. |
<!– ThinkGeo.MapSuite.Core.LayerDrawingEventArgs –> Go Back
