<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.PrinterLayer ThinkGeo.MapSuite.Core.LabelPrinterLayer
![]() | String, GeoFont, GeoBrush |
![]() | Layer | Create a copy of Layer using the deep clone process. The default implemenation uses serialization. | |
![]() | Layer | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, String | Layer | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
![]() | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | Object | ||
![]() | Layer(overriden) | ||
![]() | PrintingUnit | PrinterLayer | |
![]() | Object | ||
![]() | DrawingAttributionLayerEventArgs | Layer | |
![]() | DrawingExceptionLayerEventArgs | Layer | |
![]() | DrawingProgressChangedEventArgs | Layer | |
![]() | DrawnAttributionLayerEventArgs | Layer | |
![]() | DrawnExceptionLayerEventArgs | Layer | |
![]() | RequestedDrawingLayerEventArgs | Layer | |
![]() | RequestingDrawingLayerEventArgs | Layer | |
![]() | Layer | This method opens the Layer so that it is initialized and ready to use. | |
![]() | Double, Double, Double, Double, PrintingUnit | PrinterLayer |
![]() | String | Layer | |
![]() | AreaStyle | PrinterLayer | |
![]() | Single | Layer | This property gets and sets the amount of blue to apply to the image. |
![]() | PrinterDragMode | PrinterLayer | |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | GeoFont | ||
![]() | Single | Layer | This property gets and sets the amount of green to apply to the image. |
![]() | Boolean | Layer(overriden) | |
![]() | Boolean | PrinterLayer | |
![]() | Boolean | Layer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | Layer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | Collection<GeoColor> | Layer | Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors. |
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | PrinterWrapMode | ||
![]() | Single | Layer | This property gets and sets the amount of red to apply to the image. |
![]() | TimeSpan | Layer | |
![]() | PrinterResizeMode | PrinterLayer | |
![]() | SelectabilityMode | PrinterLayer | |
![]() | String | ||
![]() | GeoBrush | ||
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
Name | Type | Description |
Return Type | Description |
Layer<!– ThinkGeo.MapSuite.Core.Layer –> | A cloned Layer. |
Void<!– System.Void –> |
This method draws the Layer.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
This method returns the bounding box of the Layer.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns the bounding box of the Layer. |
Int32<!– System.Int32 –> |
unit | PrintingUnit<!– ThinkGeo.MapSuite.Core.PrintingUnit –> |
<!– ThinkGeo.MapSuite.Core.PrinterLayer –> Go Back
Type<!– System.Type –> |
<!– static –>
layerUri | Uri<!– System.Uri –> |
<!– static –>
layerStream | Stream<!– System.IO.Stream –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> | |
bufferTimeType | RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
width | Double<!– System.Double –> | |
height | Double<!– System.Double –> | |
centerPointX | Double<!– System.Double –> | |
centerPointY | Double<!– System.Double –> | |
corner | LayerAnchorLocation<!– ThinkGeo.MapSuite.Core.LayerAnchorLocation –> | |
cornerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
cornerPointX | Double<!– System.Double –> | |
cornerPointY | Double<!– System.Double –> | |
boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
centerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
String<!– System.String –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | |
attribution | String<!– System.String –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestingDrawingLayerEventArgs –> |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
Return Type |
Return Type |
AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
Return Type |
Single<!– System.Single –> |
Return Type |
PrinterDragMode<!– ThinkGeo.MapSuite.Core.PrinterDragMode –> |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –> |
Return Type |
Return Type |
GeoFont<!– ThinkGeo.MapSuite.Core.GeoFont –> |
<!– ThinkGeo.MapSuite.Core.LabelPrinterLayer –> Go Back
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.GeoColor} –> |
Return Type |
Return Type |
PrinterWrapMode<!– ThinkGeo.MapSuite.Core.PrinterWrapMode –> |
Return Type |
Return Type |
Return Type |
PrinterResizeMode<!– ThinkGeo.MapSuite.Core.PrinterResizeMode –> |
Return Type |
SelectabilityMode<!– ThinkGeo.MapSuite.Core.SelectabilityMode –> |
Return Type |
Return Type |
GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –> |
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
