<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.AdornmentLayer ThinkGeo.MapSuite.Core.KmlAdornmentLayer
KmlAdornmentLayer | |||
KmlAdornmentLayer | String |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetDrawingLocation | GeoCanvas, Single, Single | AdornmentLayer(overriden) | |
![]() LoadLayer | Stream | Layer | |
![]() LoadLayer | Uri | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
CloseCore | Layer(overriden) | ||
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer | This method returns the bounding box of the Layer. | |
MemberwiseClone | Object | ||
OpenCore | Layer(overriden) |
BackgroundMask | AreaStyle | AdornmentLayer | |
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
Height | Single | AdornmentLayer | |
KmlPathFilename | String | ||
Location | AdornmentLocation | AdornmentLayer | This property gets and sets the drawing location of the AdornmentLayer. |
Width | Single | AdornmentLayer | |
XOffsetInPixel | Single | AdornmentLayer | This property gets and sets the X pixel offset for the AdornmentLayer. |
YOffsetInPixel | Single | AdornmentLayer | This property gets and sets the Y pixel offset for the AdornmentLayer. |
kmlPathFilename | String |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
| kmlPathFilename | String<!– System.String –> |
| ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> |
| adornmentWidth | Single<!– System.Single –> | |
| adornmentHeight | Single<!– System.Single –> |
<!– ThinkGeo.MapSuite.Core.AdornmentLayer(overriden) –> Go Back
<!– static –>
<!– static –>
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
<!– ThinkGeo.MapSuite.Core.AdornmentLayer –> Go Back
The default value is false.
<!– ThinkGeo.MapSuite.Core.KmlAdornmentLayer –> Go Back
| AdornmentLocation<!– ThinkGeo.MapSuite.Core.AdornmentLocation –> |
This property allows you to specify an X offset. It is useful, when combined with a Y offset, to do things like modify the location of the adornment.
This property allows you to specify a Y offset. It is useful, when combined with an X offset, to do things like modify the location of the adornment.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| StreamLoadingEventArgs<!– ThinkGeo.MapSuite.Core.StreamLoadingEventArgs –> |
