thinkgeo.mapsuite.core.jpeg2000rasterlayer
ThinkGeo.MapSuite.Core.Jpeg2000RasterLayer
This class represents a .JP2 (JPEG2000) image type to be drawn on the map.
      • ThinkGeo.MapSuite.Core.RasterLayer
        • ThinkGeo.MapSuite.Core.EcwRasterLayer
          • ThinkGeo.MapSuite.Core.Jpeg2000RasterLayer
Jpeg2000RasterLayer()
If you use this constructor, then you need to set the PathFileName property manually before using the layer.
Jpeg2000RasterLayer(String)
  • imagePathFilename
    • Description:This parameter is the path and filename of the JP2 file you want to use.
Jpeg2000RasterLayer(String,String)
  • imagePathFilename
    • Description:This parameter is the path and filename of the JP2 image file you want to use.
  • worldFilePathFilename
    • Description:This parameter is the world file path and filename for the JP2 image you want to use.
Jpeg2000RasterLayer(String,RectangleShape)
  • imagePathFilename
  • imageExtent
    • Description:This parameter is the image extent of JP2 image file you want to use.
GetProjectionText()
GetHorizontalResolution()
  • Type:Single
GetVerticalResolution()
  • Type:Single
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
GetBoundingBoxCore()
OpenCore()
CloseCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
HasBoundingBox
PathFilename
ImageSource
UpperThreshold
LowerThreshold
HasProjectionText
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
IsOpenCore
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.core.jpeg2000rasterlayer.1442555107.txt.gz · Last modified: 2015/09/18 05:45 by admin
