<!– Class –> This class represents a Layer backed by a group of layers.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.GroupLayer
GroupLayer | This is the default constructor for the class. | ||
GroupLayer | IEnumerable<Layer> | This is a constructor for the class. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
![]() LoadLayer | Uri | Layer | |
![]() LoadLayer | Stream | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
CloseCore | Layer(overriden) | This method closes the FeatureSource and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the Layer. |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer(overriden) | This method returns the bounding box of the Layer. | |
MemberwiseClone | Object | ||
OpenCore | Layer(overriden) | This method opens the Layer so that it is initialized and ready to use. |
HasBoundingBox | Boolean | Layer(overriden) | This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GroupLayer, we override this API and mark it as true. |
Layers | GeoCollection<Layer> | This property gets the layers you want to use. | |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
This constructor allows you to provide the path and filename information for the group.
| layers | IEnumerable<Layer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Layer} –> | This parameter represents the layers in this class that you want to use. |
<!– static –>
<!– static –>
| bufferTime | TimeSpan<!– System.TimeSpan –> |
If you override the Core version of this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed Layer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
This abstract method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | This parameter are the labels used for collision detection and duplication checking. |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, it will open the layer as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
| GeoCollection<Layer><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.Layer} –> |
<!– ThinkGeo.MapSuite.Core.GroupLayer –> Go Back
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
