<!– Class –> GraticuleAdornmentLayer shows Meridians and Parallels displaying through the map. Meridians are lines of longitude and they have a North South orientation. Parallels are lines of latitude and they have an East West orientation. Showing graticule for latitude and longitude is a standard way in cartography to give spatial references to the users.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.AdornmentLayer ThinkGeo.MapSuite.Core.GraticuleAdornmentLayer
GraticuleAdornmentLayer | This is the default constructor of the class. | ||
GraticuleAdornmentLayer | Projection | This is a constructor for the class. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetDrawingLocation | GeoCanvas, Single, Single | AdornmentLayer | This method returns the drawing location of the AdornmentLayer. |
![]() LoadLayer | Uri | Layer | |
![]() LoadLayer | Stream | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | Layer | ||
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
CloseCore | Layer | This method closes the Layer and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the AdornmentLayer. |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer | This method returns the bounding box of the Layer. | |
MemberwiseClone | Object | ||
OpenCore | Layer(overriden) |
BackgroundMask | AreaStyle | AdornmentLayer | |
GraticuleLineStyle | LineStyle | Gets or Sets the LineStyle of the Meridians and Parallels. | |
GraticuleTextBrush | GeoBrush | Gets or Sets the GeoBrush of the Meridians and Parallels. | |
GraticuleTextFont | GeoFont | Gets or Sets the GeoFont of the Meridians and Parallels. | |
GraticuleTextHaloPen | GeoPen | ||
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
Height | Single | AdornmentLayer | |
Location | AdornmentLocation | AdornmentLayer | This property gets and sets the drawing location of the AdornmentLayer. |
Projection | Projection | Gets or Sets the Projection of the Meridians and Parallels. | |
Width | Single | AdornmentLayer | |
WrappingExtent | RectangleShape | ||
WrappingMode | WrappingMode | ||
XOffsetInPixel | Single | AdornmentLayer | This property gets and sets the X pixel offset for the AdornmentLayer. |
YOffsetInPixel | Single | AdornmentLayer | This property gets and sets the Y pixel offset for the AdornmentLayer. |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
If use this constructor, the projection is null.
This constructor allows you to pass in the Projection.
| projection | Projection<!– ThinkGeo.MapSuite.Core.Projection –> | This parameter represents the external projection which the map is actually displayed in, the internal projection is the Geodetic projection (Decimal Degrees). |
| ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> | It returns the upper left screen point of where the AdornmentLayer will be drawn. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the canvas used in drawing. |
| adornmentWidth | Single<!– System.Single –> | This parameter is the width of the adornment. |
| adornmentHeight | Single<!– System.Single –> | This parameter is the height of the adornment |
<!– ThinkGeo.MapSuite.Core.AdornmentLayer –> Go Back
<!– static –>
<!– static –>
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
This virtual method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided.
You can use the full power of the GeoCanvas to do the drawing.
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the canvas object (or a GeoImage) to draw on. |
| AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
| LineStyle<!– ThinkGeo.MapSuite.Core.LineStyle –> |
<!– ThinkGeo.MapSuite.Core.GraticuleAdornmentLayer –> Go Back
| GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –> |
| GeoFont<!– ThinkGeo.MapSuite.Core.GeoFont –> |
| GeoPen<!– ThinkGeo.MapSuite.Core.GeoPen –> |
The default value is false.
| AdornmentLocation<!– ThinkGeo.MapSuite.Core.AdornmentLocation –> |
| WrappingMode<!– ThinkGeo.MapSuite.Core.WrappingMode –> |
This property allows you to specify an X offset. It is useful, when combined with a Y offset, to do things like modify the location of the adornment.
This property allows you to specify a Y offset. It is useful, when combined with an X offset, to do things like modify the location of the adornment.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
