This class represents a TIFF image to be drawn on the map.
If you use this constructor then, you need to set the PathFileName property manually before using the layer.
GeoTiffRasterLayer(String,String)
GeoTiffRasterLayer(String,RectangleShape)
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GeoTiffRasterLayer, we override this API and mark it as true.
This property gets and sets the path and filename of the TIFF file you want to use.
This should be the complete path and filename for a TIFF file.
