thinkgeo.mapsuite.core.geoimage
ThinkGeo.MapSuite.Core.GeoImage
This class represents an image you want to use on the GeoCanvas.
    • ThinkGeo.MapSuite.Core.GeoImage
GeoImage
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This is the constructor used to create a new GeoImage.
GeoImage
  • Parameters:String
  • DeclaringType:N/A
  • Summary:This is the constructor to create a new GeoImage
GeoImage
  • Parameters:Stream
  • DeclaringType:N/A
  • Summary:This is the constructor to create a new GeoImage.
GeoImage
  • Parameters:Int32,Int32
  • DeclaringType:N/A
Close
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This method closes the GeoImage. It is the same as calling the Dispose.
Dispose
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This is the Dispose for the class.
Equals
  • Parameters:Object
  • DeclaringType:Object
  • Summary:N/A
GetHashCode
  • Parameters:N/A
  • Summary:N/A
GetHeight
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This method gets the height (in pixels) of this image.
GetImageStream
  • Parameters:GeoCanvas
  • DeclaringType:N/A
  • Summary:This method returns the stream of the GeoImage.
GetType
  • Parameters:N/A
  • Summary:N/A
GetWidth
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This method gets the width (in pixels) of this image.
ToString
  • Parameters:N/A
  • Summary:N/A
Finalize
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This is the Dispose method for the class.
GetImageStreamCore
  • DeclaringType:N/A
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
OnStreamLoading
  • DeclaringType:N/A
  • Summary:This method raises the StreamLoading event, allowing you to specify your own stream.
CanvasImageFormat
  • Return:Guid
  • Summary:This property returns the image format.
FileName
  • Return:String
  • Summary:This property returns the filename part of the PathFileName.
PathFilename
  • Return:String
  • Summary:This property returns the path and filename of the image you want to represent.
PathName
  • Return:String
  • Summary:This property returns the path part of the PathFileName.
4UI=
  • Return:Object
  • Summary:N/A
StreamLoading
  • Event Arguments:StreamLoadingEventArgs
  • Summary:This event allows you to pass in your own stream to represent the GeoImage.
GeoImage()
You need to set the PathFileName if you intend to use this constructor.
GeoImage(String)
When you specify the path and filename, it should be in the correct format as such; however, the file does not need to exist on the file system. This is to allow us to accept streams supplied by the developer at runtime. If you choose to provide a file that exists, then we will attempt to use it. If we cannot find it, then we will raise the SteamLoading event and allow you to supply the stream. For example, you can pass in “C:\NotARealPath\File1.ecw”, which does not exist on the file system. When we raise the event for you to supply a stream, we will pass to you the path and filename so you can differentiate the files.
pathFileName
  • Description:The path and filename of the image file. Note that this need not actually exisit on the file system; see remarks below. Go Back === GeoImage(Stream) === This is the constructor to create a new GeoImage. ==== Remarks ==== If you have a stream or an image in TIFF format, you can use this constructor to create a GeoImage from it. ==== Parameters ==== imageStream * Type:Stream * Description:This parameter must be a stream in TIFF format.
Go Back
GeoImage(Int32,Int32)
You can use this overload when you want to create a new GeoImage and only want to specify the width and height. You also need to pass in a GeoCanvas that will be used to create the GeoImage.
width
  • Description:This parameter is the width in pixels for the new GeoImage. height * Type:Int32 * Description:This parameter is the height in pixels for the new GeoImage.
Go Back
Close()
  • Return Type:Void
  • Description:None
Dispose()
This overload will dispose of the stream in the GeoImage and release its resources.
  • Return Type:Void
  • Description:None
  • Return Type:Boolean
obj
Go Back
  • Return Type:Int32
GetHeight()
None.
  • Return Type:Int32
  • Description:This method returns the height (in pixels) of this image.
GetImageStream(GeoCanvas)
This method will raise the event that allows the user to supply their own stream. The event is also raised if they do not attempt to open the file specified in the PathFileName property.
  • Return Type:Stream
  • Description:This method returns the stream of the GeoImage.
canvas
Go Back
  • Return Type:Type
GetWidth()
None.
  • Return Type:Int32
  • Description:This method returns the width (in pixels) of this image.
  • Return Type:String
  • Return Type:Void
GetImageStreamCore(GeoCanvas)
canvas
Go Back
  • Return Type:Object
OnStreamLoading(StreamLoadingEventArgs)
  • Return Type:Void
e
  • Description:This parameter represents the event arguments for the StreamLoading event.
Go Back
CanvasImageFormat
Return Type:Guid
Go Back
FileName
Return Type:String
Go Back
PathFilename
Return Type:String
Go Back
PathName
Return Type:String
Go Back
4UI=
Return Type:Object
Go Back
StreamLoading
If you choose, you can pass in your own stream to represent the GeoImage. The stream can come from a variety of places, such as isolated storage, a compressed file, or an encrypted stream. When the GeoImage is finished with the stream it will dispose of it, so be sure to keep this in mind when passing the stream in. If you do not pass in an alternate stream, the GeoImage will attempt to load the file from the file system using the PathFileName property.
Go Back
thinkgeo.mapsuite.core.geoimage.1442485793.txt.gz · Last modified: 2015/09/17 10:29 by admin
