Class GeoDbf.
GeoDbf(String,DbfReadWriteMode)
GeoDbf(String,DbfReadWriteMode,Encoding)
GeoDbf(String,DbfReadWriteMode,Encoding,CultureInfo)
Performs application-defined tasks associated with freeing, releasing, or resetting unmanaged resources.
ReadFieldAsBoolean(Int32,Int32)
Reads the field as boolean.
ReadFieldAsBoolean(Int32,String)
ReadFieldAsDateTime(Int32,String)
Reads the field as date time.
ReadFieldAsDateTime(Int32,Int32)
ReadFieldAsDouble(Int32,String)
Reads the field as double.
ReadFieldAsDouble(Int32,Int32)
ReadFieldAsInteger(Int32,Int32)
Reads the field as integer.
ReadFieldAsInteger(Int32,String)
ReadFieldAsString(Int32,String)
Reads the field as string.
ReadFieldAsString(Int32,Int32)
WriteField(Int32,String,Double)
Writes the field.
Writes the field.
WriteField(Int32,String,Boolean)
Writes the field.
WriteField(Int32,Int32,Double)
Writes the field.
WriteField(Int32,String,Int32)
Writes the field.
WriteField(Int32,Int32,String)
Writes the field.
WriteField(Int32,String,String)
Writes the field.
WriteField(Int32,Int32,Boolean)
Writes the field.
WriteField(Int32,Int32,DateTime)
Writes the field.
WriteField(Int32,String,DateTime)
Writes the field.
Opens this instance.
Gets the name of the column.
UpdateColumnName(Int32,String)
Updates the name of the column.
Undeletes the record.
Determines whether [is record deleted] [the specified record number].
WriteRecord(Int32,IEnumerable<Object>)
Writes the record.
CopyDbfHeader(String,String,OverwriteMode)
Copies the DBF header.
CreateDbfFile(String,IEnumerable<DbfColumn>)
Creates the DBF file.
CreateDbfFile(String,IEnumerable<DbfColumn>,OverwriteMode)
CreateDbfFile(String,IEnumerable<DbfColumn>,OverwriteMode,Encoding)
GetValidColumns(IEnumerable<DbfColumn>)
Gets the valid columns.
GetValidColumns(IEnumerable<DbfColumn>,Encoding)
GetValidColumnNames(IEnumerable<String>)
Gets the valid column names.
GetValidColumnNames(IEnumerable<String>,Encoding)
