thinkgeo.mapsuite.core.geocollection_1
ThinkGeo.MapSuite.Core.GeoCollection<T>
    • System.Collections.ObjectModel.Collection<T>
      • ThinkGeo.MapSuite.Core.GeoCollection<T>
GeoCollection`1()
This is the default constructor for the class.
GetKeys()
This method returns a collection of the keys in the collection.
  • Type:Collection<String>
  • Description:This method returns a collection of the keys in the collection.
Add(String,T)
  • key
  • item
    • Type:T
Add(T)
  • item
    • Type:T
Insert(Int32,T)
  • index
  • item
    • Type:T
Insert(Int32,String,T)
  • index
  • key
  • item
    • Type:T
Remove(String)
This method removes an item from the collection based on the specified key.
  • Description:None
  • key
    • Description:This parameter is the key of the item you want to remove.
MoveUp(Int32)
This method moves an item up in the collection.
  • Description:None
  • index
    • Description:This parameter is the index of the item in the collection.
MoveUp(String)
  • Description:None
  • key
    • Description:This parameter is the key of the item in the collection.
MoveUp(T)
  • item
    • Type:T
MoveDown(Int32)
This method moves an item down in the collection.
  • Description:None
  • index
MoveDown(String)
  • Description:None
  • key
    • Description:This parameter is the key of the item in the dictionary.
MoveDown(T)
  • item
    • Type:T
MoveToTop(Int32)
This method moves the item at the specified index to the top of the collection.
  • Description:None
  • index
    • Description:This parameter is the index of the item you want move to the top of the collection.
MoveToTop(String)
This method moves the item with the specified key to the top of the collection.
  • Description:None
  • key
    • Description:This parameter is the key of the item you want move to the top of the collection.
MoveToTop(T)
  • item
    • Type:T
MoveToBottom(Int32)
This method moves the item at the specified index to the bottom of the collection.
  • Description:None
  • index
    • Description:This parameter is the index of the item you want move to the bottom of the collection.
MoveToBottom(String)
This method moves the item with the specified key to the bottom of the collection.
  • Description:None
  • key
    • Description:This parameter is the key of the item you want move to the bottom of the collection.
MoveToBottom(T)
  • item
    • Type:T
MoveTo(Int32,Int32)
This method moves the item at fromIndex to the location of toIndex in the collection.
  • Description:None
  • fromIndex
    • Description:This parameter is the index of the item you want move from in the collection.
  • toIndex
    • Description:This parameter is the target index that you want to move the item to in the collection.
MoveTo(String,Int32)
This method moves the item with the key you specified to the location of toIndex in the collection.
  • Description:None
  • key
    • Description:This parameter is the key of item you want to move in the collection.
  • toIndex
MoveTo(T,Int32)
  • item
    • Type:T
  • toIndex
Contains(String)
This method returns whether an item is in the collection based on the specified key.
  • Description:This method returns whether an item is in the collection based on the specified key.
  • key
    • Description:This parameter is the key of the item you are searching for.
Add(T)
  • item
    • Type:T
Clear()
CopyTo(T[],Int32)
  • array
    • Type:T[]
  • index
Contains(T)
  • item
    • Type:T
GetEnumerator()
  • Type:IEnumerator<T>
IndexOf(T)
  • item
    • Type:T
Insert(Int32,T)
  • index
  • item
    • Type:T
Remove(T)
  • item
    • Type:T
RemoveAt(Int32)
  • index
OnInserting(InsertingGeoCollectionEventArgs)
OnInserted(InsertedGeoCollectionEventArgs)
OnRemoving(RemovingGeoCollectionEventArgs)
OnRemoved(RemovedGeoCollectionEventArgs)
OnAdding(AddingGeoCollectionEventArgs)
OnAdded(AddedGeoCollectionEventArgs)
OnClearingItems(ClearingItemsGeoCollectionEventArgs)
OnClearedItems(ClearedItemsGeoCollectionEventArgs)
InsertItem(Int32,T)
  • index
  • item
    • Type:T
RemoveItem(Int32)
This method removes an item from the collection based on the specified index.
  • Description:None
  • index
    • Description:This parameter is the index of the item you want to remove.
ClearItems()
This method clears the items from the collection.
  • Description:None
SetItem(Int32,T)
  • index
  • item
    • Type:T
OnCollectionChanged(NotifyCollectionChangedEventArgs)
  • e
    • Type:NotifyCollectionChangedEventArgs
OnPropertyChanged(PropertyChangedEventArgs)
  • e
    • Type:PropertyChangedEventArgs
Item
  • Type:T
Count
Item
  • Type:T
Items
  • Type:IList<T>
Inserting N/A
Event Arguments:InsertingGeoCollectionEventArgs
Inserted N/A
Event Arguments:InsertedGeoCollectionEventArgs
Removing N/A
Event Arguments:RemovingGeoCollectionEventArgs
Removed N/A
Event Arguments:RemovedGeoCollectionEventArgs
Adding N/A
Event Arguments:AddingGeoCollectionEventArgs
Added N/A
Event Arguments:AddedGeoCollectionEventArgs
ClearingItems N/A
Event Arguments:ClearingItemsGeoCollectionEventArgs
ClearedItems N/A
Event Arguments:ClearedItemsGeoCollectionEventArgs
CollectionChanged N/A
Event Arguments:
PropertyChanged N/A
Event Arguments:
thinkgeo.mapsuite.core.geocollection_1.1442554941.txt.gz · Last modified: 2015/09/18 05:42 by admin
