<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Tile *ThinkGeo.MapSuite.Core.BitmapTile ThinkGeo.MapSuite.Core.FileBitmapTile
![]() | RectangleShape, Double | ||
![]() | RectangleShape, Double, String |
![]() | Tile | This method shows the way to deep clone a Tile object. | |
![]() | BitmapTile | This method is targeting releasing or resetting unmanaged resources. | |
![]() | Object | Object | |
![]() | BitmapTile | ||
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Tile | This method shows the way to override deep clone a Tile object. | |
![]() | Object(overriden) | ||
![]() | BitmapTile(overriden) | ||
![]() | Object |
![]() | Bitmap | BitmapTile | This property is the Bitmap showing the tile image. |
![]() | RectangleShape | Tile | The Bounding box to describe the Tile. |
![]() | String | ||
![]() | Double | Tile | The scale to describe the Tile. |
Name | Type | Description |
boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
scale | Double<!– System.Double –> |
scale | Double<!– System.Double –> | |
pathFilename | String<!– System.String –> |
As this is a concrete public method that wraps a Core method, In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this,please contact our support team as we would be happy to work with you on extending our framework.
Return Type | Description |
Tile<!– ThinkGeo.MapSuite.Core.Tile –> | This method returns the cloned Tile object. |
<!– ThinkGeo.MapSuite.Core.Tile –> Go Back
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.Core.BitmapTile –> Go Back
Stream<!– System.IO.Stream –> |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
<!– ThinkGeo.MapSuite.Core.BitmapTile(overriden) –> Go Back
Return Type |
Bitmap<!– System.Drawing.Bitmap –> |
Return Type |
Return Type |
<!– ThinkGeo.MapSuite.Core.FileBitmapTile –> Go Back
Return Type |
