thinkgeo.mapsuite.core.featuresourcecolumn
ThinkGeo.MapSuite.Core.FeatureSourceColumn
FeatureSourceColumn
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This is the constructor to create a FeatureSourceColumn.
FeatureSourceColumn
  • Parameters:String
  • DeclaringType:N/A
FeatureSourceColumn
  • Parameters:String,String,Int32
  • DeclaringType:N/A
Equals
  • Parameters:Object
  • DeclaringType:Object
  • Summary:N/A
GetHashCode
  • Parameters:N/A
  • Summary:N/A
GetType
  • Parameters:N/A
  • Summary:N/A
ToString
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:Returns column name of FeatureSourceColumn
Finalize
  • Parameters:N/A
  • Summary:N/A
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
ColumnName
  • Return:String
  • Summary:This property returns the name of the column.
MaxLength
  • Return:Int32
  • Summary:This property returns the maximum length of the column.
TypeName
  • Return:String
  • Summary:This property returns the type name of the column.
FeatureSourceColumn()
This constructor is the default, but should not be used.
FeatureSourceColumn(String)
This is the constructor that should be used.
columnName
  • Description:This parameter represents the name of the column. Go Back === FeatureSourceColumn(String,String,Int32) === This is the constructor to create a FeatureSourceColumn. ==== Remarks ==== This is the constructor that should be used. ==== Parameters ==== columnName * Type:String * Description:This parameter represents the name of the column.
typeName
  • Description:This parameter represents the type name of the column. maxLength * Type:Int32 * Description:This parameter represents the maximum length of the column.
Go Back
  • Return Type:Boolean
obj
Go Back
  • Return Type:Int32
  • Return Type:Type
  • Return Type:String
  • Description:Returns column name of FeatureSourceColumn
  • Return Type:Void
  • Return Type:Object
ColumnName
Return Type:String
Go Back
MaxLength
The maximum length is user defined and not in any way enforced in our default FeatureSource implementation. It is mainly for display purposes or when dealing with a known Feature Source type.
Return Type:Int32
Go Back
TypeName
This property is freeform and the type name is not tied to anything. It is wise to try and use familiar type names such as string, integer, date, etc., although it may not fit every different type of FeatureSource. We suggest thar you avoid using this property unless you know the types beforehand or simply want them for display purposes.
Return Type:String
Go Back
thinkgeo.mapsuite.core.featuresourcecolumn.1442485727.txt.gz · Last modified: 2015/09/17 10:28 by admin
