thinkgeo.mapsuite.core.degreesminutesseconds
ThinkGeo.MapSuite.Core.DegreesMinutesSeconds
This structure represents a degrees, minutes and seconds value.
    • System.ValueType
      • ThinkGeo.MapSuite.Core.DegreesMinutesSeconds
  • Parameters:Int32,Int32,Double
  • DeclaringType:N/A
  • Summary:This constructor allows you to create an instance of the class by specifying the degree, minute and second values.
Add
  • DeclaringType:N/A
  • Summary:Add two DegreesMinutsSeconds together and return back a summary of the two.
Equals
  • Parameters:Object
  • DeclaringType:N/A
  • Summary:Compares current DegreesMinutesSeconds with a passing object.
GetFormattedString
  • Parameters:Int32
  • DeclaringType:N/A
  • Summary:This method returns a formatted representation of the degrees, minutes and seconds value that has been rounded to the specified decimals.
GetFormattedString
GetFormattedString
GetHashCode
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:Serves as hash function for the particular type.
GetType
  • Parameters:N/A
  • DeclaringType:Object
  • Summary:N/A
ToString
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This method returns a formatted representation of the degrees, minutes and seconds value.
ToString
  • Parameters:Int32
  • DeclaringType:N/A
  • Summary:N/A
Finalize
  • Parameters:N/A
  • Summary:N/A
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
Degrees
  • Return:Int32
  • Summary:This property returns the degrees portion of the structure.
Minutes
  • Return:Int32
  • Summary:This property returns the minutes portion of the structure.
Seconds
  • Return:Double
  • Summary:This property returns the seconds portion of the structure.
DegreesMinutesSeconds(Int32,Int32,Double)
degrees
  • Description:This parameter represents the degree portion of the structure. minutes * Type:Int32 * Description:This parameter represents the minute portion of the structure.
seconds
  • Description:This parameter represents the second portion of the structure. Go Back ===== Protected Constructors ===== ===== Public Methods ===== === Add(DegreesMinutesSeconds) === Add two DegreesMinutsSeconds together and return back a summary of the two. ==== Remarks ==== N/A Return Value * Return Type:DegreesMinutesSeconds * Description:The summary of the two DegreesMinutesSeconds. ==== Parameters ==== targetDegreesMinutesSeconds * Type:DegreesMinutesSeconds * Description:The target DegreesMinutesSeconds to be added together. Go Back === Equals(Object) === Compares current DegreesMinutesSeconds with a passing object. ==== Remarks ==== N/A Return Value * Return Type:Boolean * Description:True if the passing object satisfies the following two conditions:1) The object is of DegreesMinutesSeconds type.2) The Degrees, Minutes and Seconds of both DegreesMinutesSeconds should be the same.If both conditions are not met, will return false. ==== Parameters ==== obj * Type:Object * Description:The passing object which will be used to compare with current DegreesMinutesSeconds. Go Back === GetFormattedString(Int32) === This method returns a formatted representation of the degrees, minutes and seconds value that has been rounded to the specified decimals. ==== Remarks ==== The value will be formatted in the standard string format. For example, 75º 21' 2.1235“ (when the decimals parameter is set to 4). Return Value * Return Type:String * Description:This method returns a formatted representation of the degrees, minutes and seconds value. ==== Parameters ==== decimals * Type:Int32 * Description:The target decimals that the degrees, minutes, seconds value will be rounded to. Go Back === GetFormattedString(DegreesMinutesSecondsFormatType) === N/A ==== Remarks ==== N/A Return Value * Return Type:String * Description:N/A ==== Parameters ==== formatType * Type:DegreesMinutesSecondsFormatType * Description:N/A Go Back === GetFormattedString(DegreesMinutesSecondsFormatType,Int32) === N/A ==== Remarks ==== N/A Return Value * Return Type:String * Description:N/A ==== Parameters ==== formatType * Type:DegreesMinutesSecondsFormatType * Description:N/A decimals * Type:Int32 * Description:N/A Go Back === GetHashCode() === Serves as hash function for the particular type. ==== Remarks ==== N/A Return Value * Return Type:Int32 * Description:The hash code for this particular type. ==== Parameters ==== Go Back === GetType() === N/A ==== Remarks ==== N/A Return Value * Return Type:Type * Description:N/A ==== Parameters ==== Go Back === ToString() === This method returns a formatted representation of the degrees, minutes and seconds value. ==== Remarks ==== The value will be formatted in the standard string format: 75º 21' 28” Return Value * Return Type:String * Description:This method returns a formatted representation of the degrees, minutes and seconds value. ==== Parameters ==== Go Back === ToString(Int32) === N/A ==== Remarks ==== N/A Return Value * Return Type:String * Description:N/A ==== Parameters ==== decimals * Type:Int32 * Description:N/A Go Back ===== Protected Methods ===== === Finalize() === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== Go Back === MemberwiseClone() === N/A ==== Remarks ==== N/A Return Value * Return Type:Object * Description:N/A ==== Parameters ==== Go Back ===== Public Properties ===== === Degrees === This property returns the degrees portion of the structure. ==== Remarks ==== None ==== Return Value ==== Return Type:Int32 Go Back === Minutes === This property returns the minutes portion of the structure. ==== Remarks ==== None ==== Return Value ==== Return Type:Int32 Go Back === Seconds === This property returns the seconds portion of the structure. ==== Remarks ==== None ==== Return Value ==== Return Type**:Double
Go Back
thinkgeo.mapsuite.core.degreesminutesseconds.1442485645.txt.gz · Last modified: 2015/09/17 10:27 by admin
