<!– Structure –> This structure represents a degrees, minutes and seconds value.
This structure is used in many places to represent decimal degree numbers as degrees, minutes and seconds.
*System.ValueType **ThinkGeo.MapSuite.Core.DegreesMinutesSeconds
DegreesMinutesSeconds | Int32, Int32, Double | This constructor allows you to create an instance of the class by specifying the degree, minute and second values. |
Add | DegreesMinutesSeconds | Add two DegreesMinutsSeconds together and return back a summary of the two. | |
Equals | Object | Object(overriden) | Compares current DegreesMinutesSeconds with a passing object. |
GetFormattedString | Int32 | This method returns a formatted representation of the degrees, minutes and seconds value that has been rounded to the specified decimals. | |
GetFormattedString | DegreesMinutesSecondsFormatType | ||
GetFormattedString | DegreesMinutesSecondsFormatType, Int32 | ||
GetHashCode | Object(overriden) | Serves as hash function for the particular type. | |
ToString | Object(overriden) | This method returns a formatted representation of the degrees, minutes and seconds value. |
| degrees | Int32<!– System.Int32 –> | This parameter represents the degree portion of the structure. |
| minutes | Int32<!– System.Int32 –> | This parameter represents the minute portion of the structure. |
| seconds | Double<!– System.Double –> | This parameter represents the second portion of the structure. |
| DegreesMinutesSeconds<!– ThinkGeo.MapSuite.Core.DegreesMinutesSeconds –> | The summary of the two DegreesMinutesSeconds. |
| targetDegreesMinutesSeconds | DegreesMinutesSeconds<!– ThinkGeo.MapSuite.Core.DegreesMinutesSeconds –> | The target DegreesMinutesSeconds to be added together. |
<!– ThinkGeo.MapSuite.Core.DegreesMinutesSeconds –> Go Back
| Boolean<!– System.Boolean –> | True if the passing object satisfies the following two conditions:1) The object is of DegreesMinutesSeconds type.2) The Degrees, Minutes and Seconds of both DegreesMinutesSeconds should be the same.If both conditions are not met, will return false. |
| obj | Object<!– System.Object –> | The passing object which will be used to compare with current DegreesMinutesSeconds. |
The value will be formatted in the standard string format. For example, 75º 21' 2.1235“ (when the decimals parameter is set to 4).
| String<!– System.String –> | This method returns a formatted representation of the degrees, minutes and seconds value. |
| decimals | Int32<!– System.Int32 –> | The target decimals that the degrees, minutes, seconds value will be rounded to. |
| formatType | DegreesMinutesSecondsFormatType<!– ThinkGeo.MapSuite.Core.DegreesMinutesSecondsFormatType –> |
| formatType | DegreesMinutesSecondsFormatType<!– ThinkGeo.MapSuite.Core.DegreesMinutesSecondsFormatType –> | |
| Int32<!– System.Int32 –> | The hash code for this particular type. |
The value will be formatted in the standard string format: 75º 21' 28”
This property returns the degrees portion of the structure.
This property returns the minutes portion of the structure.
This property returns the seconds portion of the structure.
