thinkgeo.mapsuite.core.conversion
ThinkGeo.MapSuite.Core.Conversion
This static class provides a conversion method to go to and from different units.
    • ThinkGeo.MapSuite.Core.Conversion
ConvertMeasureUnits(Double,DistanceUnit,DistanceUnit)
This method converts from one unit of measure to another.
  • Description:The return length size, represented in the unit specified in the toUnit parameter.
  • amount
    • Description:The total length size, represented in the unit specified in the fromUnit parameter.
  • fromUnit
    • Description:The unit of measure for the length in the Amount parameter.
  • toUnit
    • Description:The unit of measure for the result.
ConvertMeasureUnits(Double,AreaUnit,AreaUnit)
  • Description:The return area size, represented in the unit specified in the toUnit parameter.
  • amount
    • Description:The total area size, represented in the unit specified in the fromUnit parameter.
  • fromUnit
    • Type:AreaUnit
    • Description:The unit of measure for the area in the Amount parameter.
  • toUnit
    • Type:AreaUnit
ConvertAngleUnits(Double,AngleUnit,AngleUnit)
  • angle
I0M=(Double,ScreenUnit,ScreenUnit)
  • amount
Ujc=(GeographyUnit)
JEM=(Single)
  • degrees
    • Type:Single
GBQ=(PointShape,PointShape)
GRQ=(Double)
  • angle
thinkgeo.mapsuite.core.conversion.1442554776.txt.gz · Last modified: 2015/09/18 05:39 by admin
