thinkgeo.mapsuite.core.classbreak
ThinkGeo.MapSuite.Core.ClassBreak
This class represents a single class break.
    • ThinkGeo.MapSuite.Core.ClassBreak
ClassBreak
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This is the class constructor.
ClassBreak
  • Parameters:Double,AreaStyle
  • DeclaringType:N/A
ClassBreak
  • Parameters:Double,PointStyle
  • DeclaringType:N/A
ClassBreak
  • Parameters:Double,LineStyle
  • DeclaringType:N/A
ClassBreak
  • Parameters:Double,TextStyle
  • DeclaringType:N/A
ClassBreak
  • Parameters:Double,Collection<Style>
  • DeclaringType:N/A
Equals
  • Parameters:Object
  • DeclaringType:Object
  • Summary:N/A
GetHashCode
  • Parameters:N/A
  • Summary:N/A
GetType
  • Parameters:N/A
  • Summary:N/A
ToString
  • Parameters:N/A
  • Summary:N/A
Finalize
  • Parameters:N/A
  • Summary:N/A
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
CustomStyles
  • Return:Collection<Style>
  • Summary:This property gets a collection of custom styles used to draw the class break.
DefaultAreaStyle
  • Return:AreaStyle
  • Summary:This property gets and sets the default AreaStyle used to draw the class break.
DefaultLineStyle
  • Return:LineStyle
  • Summary:This property gets and sets the default LineStyle used to draw the class break.
DefaultPointStyle
  • Return:PointStyle
  • Summary:This property gets and sets the default PointStyle used to draw the class break.
DefaultTextStyle
  • Return:TextStyle
  • Summary:This property gets and sets the default TextStyle used to draw the class break.
Value
  • Return:Double
  • Summary:This property get and sets the break value.
ClassBreak()
If you use this default constructor, then you should set the properties manually.
ClassBreak(Double,AreaStyle)
This overload allows you to pass in a break value and an AreaStyle to use.
value
  • Description:The parameter represents the break value. areaStyle * Type:AreaStyle * Description:This parameter is the AreaStyle you want to use to represent this break.
Go Back
ClassBreak(Double,PointStyle)
This overload allows you to pass in a break value and a Point to use.
value
  • Description:The parameter represents the break value. pointStyle * Type:PointStyle * Description:This parameter is the PointStyle you want to use to represent this break.
Go Back
ClassBreak(Double,LineStyle)
This overload allows you to pass in a break value and a LineStyle to use.
value
  • Description:The parameter represents the break value. lineStyle * Type:LineStyle * Description:This parameter is the LineStyle you want to use to represent this break.
Go Back
ClassBreak(Double,TextStyle)
This overload allows you to pass in a break value and a TextStyle to use.
value
  • Description:The parameter represents the break value. textStyle * Type:TextStyle * Description:This parameter is the TextStyle you want to use to represent this break.
Go Back
ClassBreak(Double,Collection<Style>)
This overload allows you to pass in a break value and a collection of TextStyles to use.
value
  • Description:The parameter represents the break value. customStyles * Type:Collection<Style> * Description:This parameter is the TextStyles you want to use to represent this break.
Go Back
  • Return Type:Boolean
obj
Go Back
  • Return Type:Int32
  • Return Type:Type
  • Return Type:String
  • Return Type:Void
  • Return Type:Object
CustomStyles
If you set these styles, then when the data for a feature is within the current break it will use this style to draw. If you do not wish to use the default style properties, then you can use this collection to specify any types of styles you want to use.
Return Type:Collection<Style>
Go Back
DefaultAreaStyle
If you set this style, then when the data for a feature is within the current break it will use this style to draw. If you use the default styles, then you should only use one. The one you use should match your feature data. For example, if your features are lines, then you should use the DefaultLineStyle.
Return Type:AreaStyle
Go Back
DefaultLineStyle
Return Type:LineStyle
Go Back
DefaultPointStyle
Return Type:PointStyle
Go Back
DefaultTextStyle
If you set this style, then when the data for a feature is within the current break it will use this style to draw. If you use the default styles, then you should only use one. The one you use should match your feature data. For example, if your features are lines then you should use the DefaultLineStyle.
Return Type:TextStyle
Go Back
Value
This value determines where the break is in the ClassBreakStyle. Please see the ClassBreakStyle class remarks for a full description of how the ClassBreakStyle works.
Return Type:Double
Go Back
thinkgeo.mapsuite.core.classbreak.1442485572.txt.gz · Last modified: 2015/09/17 10:26 by admin
