thinkgeo.mapsuite.core.bitmaptile
ThinkGeo.MapSuite.Core.BitmapTile
This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
BitmapTile()
This is the default constructor without passing any parameters. All its properties should be set via the properties.
BitmapTile(RectangleShape,Double)
This is the constructor for Tile by passing the boundingBox and scale.
  • scale
BitmapTile(Bitmap,RectangleShape,Double)
This is the constructor for Tile by passing image bitmap and the boundingBox and scale.
  • bitmap
    • Type:Bitmap
  • scale
GetBitmapStream()
  • Type:Stream
Dispose()
This method is targeting releasing or resetting unmanaged resources.
CloneDeep()
  • Type:Tile
GetBitmapStreamCore()
  • Type:Stream
This method is the destructorof this class. Destructor cannot be called and only will be invoked automatically.
CloneDeepCore()
  • Type:Tile
Bitmap
This property is the Bitmap showing the tile image.
  • Type:Bitmap
Scale
BoundingBox
thinkgeo.mapsuite.core.bitmaptile.1442554705.txt.gz · Last modified: 2015/09/18 05:38 by admin
