<!– Class –> This class represents the advanced drawing options for area styles.
This class allows you to set the FillCustomBrush. This enables you to use custom brushes to achieve effects such as linear gradients and bitmap fills.
*System.Object **ThinkGeo.MapSuite.Core.AreaStyleAdvanced
![]() | This is the default constructor for the class. |
![]() | Create a copy of AreaStyleAdvanced class using the deep clone process. | ||
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | GeoBrush | This property allows you to get and set a custom fill brush. |
Name | Type | Description |
Return Type | Description |
AreaStyleAdvanced<!– ThinkGeo.MapSuite.Core.AreaStyleAdvanced –> | A cloned AreaStyleAdvanced. |
<!– ThinkGeo.MapSuite.Core.AreaStyleAdvanced –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
This allows you to use custom brushes to achieve effects such as linear gradients and bitmap fills. If you use any brush besides the SolidBrush, you would set it in this property.
Return Type |
GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –> |
