thinkgeo.mapsuite.core.adornmentlayerdrawingeventargs
ThinkGeo.MapSuite.Core.AdornmentLayerDrawingEventArgs
      • ThinkGeo.MapSuite.Core.AdornmentLayerDrawingEventArgs
AdornmentLayerDrawingEventArgs()
This is the default constructor for the class.
AdornmentLayerDrawingEventArgs(AdornmentLayer)
  • adornmentLayer
    • Description:This parameter is the AdornmentLayer that will be drawn.
AdornmentLayer
This property gets and sets the AdornmentLayer that will be drawn.
thinkgeo.mapsuite.core.adornmentlayerdrawingeventargs.1442397553.txt.gz · Last modified: 2015/09/16 09:59 by admin
