This is the event arguments class for the AdornmentLayerDrawing event. It is raised before the AdornmentLayer is drawn. This event allows you to manipulate the AdornmentLayer, or draw something with the canvas before the AdornmentLayer draws.
![]() | This is the default constructor for the class. | ||
![]() | AdornmentLayer | This is a constructor for the class. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | AdornmentLayer | This property gets and sets the AdornmentLayer that will be drawn. |
Name | Type | Description |
adornmentLayer | AdornmentLayer | This parameter is the AdornmentLayer that will be drawn. |
Return Type | Description |
Boolean |
obj | Object |
Int32 |
Type |
String |
Void |
Object |
Return Type |
AdornmentLayer |
