thinkgeo.mapsuite.androidedition.maptools
ThinkGeo.MapSuite.AndroidEdition.MapTools
Contains the different map tools as properties and acts as an entrance for setting these map controls.
MapTools(Context,MapView)
  • context
    • Type:Context
    • Description:Interface to global information about an application environment.
  • currentMap
    • Type:MapView
    • Description:A mapView object that all map tools in this object is based on.
Refresh()
Refreshes all the map tools objects maintaining in the MapTools object.
GetKeys()
  • Type:Collection<String>
Add(String,MapTool)
  • key
  • item
Add(MapTool)
  • item
Insert(Int32,MapTool)
  • index
  • item
Insert(Int32,String,MapTool)
  • index
  • key
  • item
Remove(String)
  • key
MoveUp(Int32)
  • index
MoveUp(String)
  • key
MoveUp(MapTool)
  • item
MoveDown(Int32)
  • index
MoveDown(String)
  • key
MoveDown(MapTool)
  • item
MoveToTop(Int32)
  • index
MoveToTop(String)
  • key
MoveToTop(MapTool)
  • item
MoveToBottom(Int32)
  • index
MoveToBottom(String)
  • key
MoveToBottom(MapTool)
  • item
MoveTo(Int32,Int32)
  • fromIndex
  • toIndex
MoveTo(String,Int32)
  • key
  • toIndex
MoveTo(MapTool,Int32)
  • item
  • toIndex
Contains(String)
  • key
Add(MapTool)
  • item
Clear()
CopyTo(MapTool[],Int32)
  • index
Contains(MapTool)
  • item
GetEnumerator()
  • Type:IEnumerator<MapTool>
IndexOf(MapTool)
  • item
  • index
  • item
Remove(MapTool)
  • item
RemoveAt(Int32)
  • index
OnInserting(InsertingGeoCollectionEventArgs)
OnInserted(InsertedGeoCollectionEventArgs)
OnRemoving(RemovingGeoCollectionEventArgs)
OnRemoved(RemovedGeoCollectionEventArgs)
OnAdding(AddingGeoCollectionEventArgs)
OnAdded(AddedGeoCollectionEventArgs)
OnClearingItems(ClearingItemsGeoCollectionEventArgs)
OnClearedItems(ClearedItemsGeoCollectionEventArgs)
InsertItem(Int32,MapTool)
  • index
  • item
RemoveItem(Int32)
  • index
ClearItems()
SetItem(Int32,MapTool)
  • index
  • item
OnCollectionChanged(NotifyCollectionChangedEventArgs)
  • e
    • Type:NotifyCollectionChangedEventArgs
OnPropertyChanged(PropertyChangedEventArgs)
  • e
    • Type:PropertyChangedEventArgs
ZoomMapTool
Gets the zoom map tool.
CenterCoordinate
Gets the center coordinate.
Item
Count
Item
Items
Inserting N/A
Event Arguments:InsertingGeoCollectionEventArgs
Inserted N/A
Event Arguments:InsertedGeoCollectionEventArgs
Removing N/A
Event Arguments:RemovingGeoCollectionEventArgs
Removed N/A
Event Arguments:RemovedGeoCollectionEventArgs
Adding N/A
Event Arguments:AddingGeoCollectionEventArgs
Added N/A
Event Arguments:AddedGeoCollectionEventArgs
ClearingItems N/A
Event Arguments:ClearingItemsGeoCollectionEventArgs
ClearedItems N/A
Event Arguments:ClearedItemsGeoCollectionEventArgs
CollectionChanged N/A
Event Arguments:
PropertyChanged N/A
Event Arguments:
thinkgeo.mapsuite.androidedition.maptools.1442831448.txt.gz · Last modified: 2015/09/21 10:30 by admin
