<!– Class –> Contains the different map tools as properties and acts as an entrance for setting these map controls.
This class is designed to be easy to use. It contains all the available tools of the map. You can find and set those map tools easily by using this class.
*System.Object
* AndroidEdition System.Collections.ObjectModel.Collection‹T›[[ThinkGeo.MapSuite.AndroidEdition.MapTool * PublicKeyToken=0828af5241fb4207]] Culture=neutral * Version=8.0.0.0 AndroidEdition *ThinkGeo.MapSuite.Core.GeoCollection‹T›[[ThinkGeo.MapSuite.AndroidEdition.MapTool ThinkGeo.MapSuite.AndroidEdition.MapTools
ClearItems | Collection<MapTool>(overriden) | ||
InsertItem | Int32, MapTool | Collection<MapTool>(overriden) | |
MemberwiseClone | Object | ||
OnAdded | AddedGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnAdding | AddingGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnClearedItems | ClearedItemsGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnClearingItems | ClearingItemsGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnCollectionChanged | NotifyCollectionChangedEventArgs | GeoCollection<MapTool> | |
OnInserted | InsertedGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnInserting | InsertingGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnPropertyChanged | PropertyChangedEventArgs | GeoCollection<MapTool> | |
OnRemoved | RemovedGeoCollectionEventArgs | GeoCollection<MapTool> | |
OnRemoving | RemovingGeoCollectionEventArgs | GeoCollection<MapTool> | |
RemoveItem | Int32 | Collection<MapTool>(overriden) | |
SetItem | Int32, MapTool | Collection<MapTool>(overriden) |
CenterCoordinate | CenterCoordinateMapTool | Gets the center coordinate. | |
Count | Int32 | Collection<MapTool> | |
Item | MapTool | GeoCollection<MapTool> | |
Item | MapTool | Collection<MapTool> | |
ZoomMapTool | ZoomMapTool | Gets the zoom map tool. |
| context | Context<!– Android.Content.Context –> | Interface to global information about an application environment. |
| currentMap | MapView<!– ThinkGeo.MapSuite.AndroidEdition.MapView –> | A mapView object that all map tools in this object is based on. |
| item | MapTool<!– ThinkGeo.MapSuite.AndroidEdition.MapTool –> |
<!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.AndroidEdition.MapTool} –> Go Back
| key | String<!– System.String –> | |
<!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.AndroidEdition.MapTool} –> Go Back
| array | MapTool[]<!– ThinkGeo.MapSuite.AndroidEdition.MapToolthinkgeo.mapsuite.androidedition.maptools –> | |
| index | Int32<!– System.Int32 –> |
| IEnumerator<MapTool><!– System.Collections.Generic.IEnumerator{ThinkGeo.MapSuite.AndroidEdition.MapTool} –> |
| index | Int32<!– System.Int32 –> | |
| toIndex | Int32<!– System.Int32 –> |
| fromIndex | Int32<!– System.Int32 –> | |
| item | MapTool<!– ThinkGeo.MapSuite.AndroidEdition.MapTool –> | |
Refreshes all the map tools objects maintaining in the MapTools object.
<!– ThinkGeo.MapSuite.AndroidEdition.MapTools –> Go Back
<!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.AndroidEdition.MapTool}(overriden) –> Go Back
| e | AddedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.AddedGeoCollectionEventArgs –> |
| e | AddingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.AddingGeoCollectionEventArgs –> |
| e | ClearedItemsGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.ClearedItemsGeoCollectionEventArgs –> |
| e | ClearingItemsGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.ClearingItemsGeoCollectionEventArgs –> |
| e | NotifyCollectionChangedEventArgs<!– System.Collections.Specialized.NotifyCollectionChangedEventArgs –> |
| e | InsertedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.InsertedGeoCollectionEventArgs –> |
| e | InsertingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.InsertingGeoCollectionEventArgs –> |
| e | PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
| e | RemovedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.RemovedGeoCollectionEventArgs –> |
| e | RemovingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.RemovingGeoCollectionEventArgs –> |
| CenterCoordinateMapTool<!– ThinkGeo.MapSuite.AndroidEdition.CenterCoordinateMapTool –> |
| ZoomMapTool<!– ThinkGeo.MapSuite.AndroidEdition.ZoomMapTool –> |
| IList<MapTool><!– System.Collections.Generic.IList{ThinkGeo.MapSuite.AndroidEdition.MapTool} –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC AndroidEdition ThinkGeo.MapSuite.AndroidEdition UpdateDocumentation
