Points for labeling major marine features, such as the oceans, seas, bays, gulfs and channels.
geometry type : point
| Field | Description |
| name | The name (or names) used locally for the place. |
| name_en | English (if available, otherwise same as name) |
| name_zh | Chinese (if available, otherwise same as name) |
| name_ar | Arabic (if available, otherwise same as name) |
| name_de | German name name_deif available, otherwise nameor name_en. |
The main field used for styling the marine is class. The varying number represent different values.
| Value | Description |
| 0- -'ocean' | There are seven continents. |
| 1- -'sea' | A sea is a large body of salt water which is surrounded by land. |
| 2- -'bay' | A bay is a recessed, coastal body of the water directly connects to a larger main body for water,such as Bay of plenty. |
| 3- -'gulf' | A gulf is a large bay that is an arm of the ocean or the sea. |
| 4- -'channel' | A channel consists the outline of the path of a narrow body of water. |
