The Map Suite Xamarin.Forms illustrated QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This edition of the QuickStart Guide supports Map Suite 9.0.0.0 and higher, and will show you how to create an Mobile application using Xamarin.Forms for Map Suite iOS or Android Editions.
Before we get started, make sure you've installed the ThinkGeo Product Center and that you've either started an evaluation or activated a full license of Map Suite iOS or Android Edition. By default, this will install the Map Suite 9.0 Xamarin.Forms assemblies to C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Xamarin Forms.
Please following our Xamarin.Forms Installation Guide for Xamarin.Forms development environment.
Let's start by creating a new Forms blank app in Microsoft Visual Studio (2012 or newer) named HelloWorld (see Figure 1). We can create the project with .NET Framework 4.5 or higher.
The project HelloWorld is created in a new solution called HelloWorld. The wizard creates a single blank Application(Xamarin.Forms.Portable).
After you created a HelloWorld project, we will see three projects in the solution, please see Figure 2.
We need to add MapSuiteProtableCore.dll and MapSuiteFormsEdition.dll to the “HelloWorld” project which we will work mainly. Right-click the Reference in Solution Explorer and select “Add Reference”, we can find “MapSuitePortableCore.dll” in two products(iOS or Android) at C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite AndroidSuite iOS\Current Version\Managed Assemblies. then navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Xamarin Forms\Current Version\Managed Assemblies folder and select “MapSuiteFormsEdition.dll”.
xamarin_forms_quickStart_Screenshot3.png|Figure 3. Add Reference to HelloWorld.
For android platform, we need to add AndroidEdition.dll, MapSuiteFormsEdition.dll and MapSuiteFormsEdition.Android.dll to “HelloWorld.Droid” project. Right-click the Reference in Solution Explorer and select “Add Reference”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Xamarin Forms\Current Version\Managed Assemblies folder and select “MapSuiteFormsEdition.Android.dll” and “MapSuiteFormsEdition.dll”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Android\Current Version\Managed Assemblies folder and select “AndroidEdition.dll”.
xamarin_forms_quickStart_Screenshot4.png|Figure 4. Add Reference to HelloWorld.Droid.
The next step is to Initialize MapSuiteForms, MainActivity.cs:
public class MainActivity : global::Xamarin.Forms.Platform.Android.FormsApplicationActivity { protected override void OnCreate(Bundle bundle) { base.OnCreate(bundle); Forms.Init(this, bundle); MapSuiteForms.Init(); LoadApplication(new App()); } }
For iOS platform, we need to add iOSEdition.dll, MapSuiteFormsEdition.dll and MapSuiteFormsEdition.iOS.dll to “HelloWorld.iOS” project. Right-click the Reference in Solution Explorer and select “Add Reference”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Xamarin Forms\Current Version\Managed Assemblies folder and select “MapSuiteFormsEdition.dll” and “MapSuiteFormsEdition.iOS.dll”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite iOS\Current Version\Managed Assemblies folder and select “iOSEdition.dll”.
xamarin_forms_quickStart_Screenshot5.png|Figure 5. Add Reference to HelloWorld.iOS.
The next step is to Initialize MapSuiteForms, AppDeleagte.cs:
[[Register("AppDelegate")]] public partial class AppDelegate : global::Xamarin.Forms.Platform.iOS.FormsApplicationDelegate { public override bool FinishedLaunching(UIApplication app, NSDictionary options) { Forms.Init(); MapSuiteForms.Init(); LoadApplication(new App()); return base.FinishedLaunching(app, options); } }
The next step is to create Map view in the constructor of App, and define it as “mapView”.
public App() { MapView mapView = new MapView(); MainPage = new ContentPage { Content = new StackLayout { Children = { mapView } } }; }
The first step in creating our “Hello World” sample application is to set references to the ThinkGeo.MapSuite.Core and ThinkGeo.MapSuite.FormsEdition workspaces at the very top of our code, since we'll use many classes within them. Set the reference like this:
using ThinkGeo.MapSuite.Core; using ThinkGeo.MapSuite.FormsEdition;
Now, let's add a base overlay to display the world map witch called “WorldMapKitOverlay”.
public App() { MapView mapView = new MapView(); // Set the Map Unit to DecimalDegrees, the Shapefile’s unit of measure. mapView.MapUnit = GeographyUnit.DecimalDegree; // Create a WorldMapKitOverlay. WorldMapKitOverlay worldMapKitOverlay = new WorldMapKitOverlay(); // Add a WorldMapKitOverlay. mapView.Overlays.Add("WorldMapKit", worldMapKitOverlay); // Set a proper extent for the map. The extent is the geographical area you want it to display. mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26); MainPage = new ContentPage { Content = new StackLayout() { Children = { mapView } } }; }
If we compile and run what we have now, our map should look like the one below (see Figure 6).
capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 7, GeoColor.StandardColors.Brown); capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05;
Android The data used here can be found in the attached sample above in the “\AppData” folder. And we has copy data to sdcard. Please check data, and make sure we can find it in sdcard (“/mnt/sdcard/Android.Sample/”).
iOS The data used here can be found in the attached sample above in the “\AppData” folder. The data files' build action should be “Content”.
Our next step is to define and add our Layers. Here is the code to use for our example. All of the following code can be placed in the the constructor of App.
public App() { MapView mapView = new MapView(); // Set the Map Unit to DecimalDegrees, the Shapefile’s unit of measure. mapView.MapUnit = GeographyUnit.DecimalDegree; // Get the base data location on different platform. string baseDataPath = Device.OnPlatform<string>("", "/mnt/sdcard/Android.Sample/", ""); // Set the Map Unit to DecimalDegrees, the Shapefile’s unit of measure. mapView.MapUnit = GeographyUnit.DecimalDegree; WorldMapKitOverlay worldMapKitOverlay = new WorldMapKitOverlay(); mapView.Overlays.Add("WorldMapKit", worldMapKitOverlay); // Create a new Layer and pass the path to a Shapefile into its constructor. ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/Countries02.shp"); <nowiki>//</nowiki> Set the worldLayer with a preset Style, as AreaStyles.Country1 has YellowGreen background and black border, our worldLayer will have the same render style. worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1; // This setting will apply from ZoomLevel01 to ZoomLevel20, which means the map will be rendered in the same style, no matter how far we zoom in or out. worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // Create a new Layer Overlay to hold the layer we just created LayerOverlay layerOverlay = new LayerOverlay(); // Add the shapefile layer to the layer overlay layerOverlay.Layers.Add(worldLayer); // Add the layerOverlay to map. mapView.Overlays.Add(layerOverlay); // Set a proper extent for the map. The extent is the geographical area you want it to display. mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26); MainPage = new ContentPage { Content = new StackLayout() { Children = { mapView } } }; }
If you compile and run, your map should look like the one below. (see Figure 7).
Figure 7. A Simple map of Europe (Android left, iOS right).
Now you can display and navigate your map. Pan by dragging the map, zoom in by double-clicking, zoom in and out with the gesture. Very powerful for just couple lines of code, isn't it?
public App() { MapView mapView = new MapView(); mapView.MapUnit = GeographyUnit.DecimalDegree; string baseDataPath = Device.OnPlatform<string>("", "/mnt/sdcard/Android.Sample/", ""); WorldMapKitOverlay worldMapKitOverlay = new WorldMapKitOverlay(); mapView.Overlays.Add("WorldMapKit", worldMapKitOverlay); ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/Countries02.shp"); worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/WorldCapitals.shp"); // Similarly, we use the presetPointStyle for cities. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital3; // This setting also applies from ZoomLevel01 to ZoomLevel20, so city symbols will be rendered in the same style, no matter how far we zoom in or out. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; LayerOverlay layerOverlay = new LayerOverlay(); layerOverlay.Layers.Add(worldLayer); // We need to add both of the new layers to the Layer OverLay. layerOverlay.Layers.Add(capitalLayer); mapView.Overlays.Add(layerOverlay); mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26); MainPage = new ContentPage { Content = new StackLayout() { Children = { mapView } } }; }
If you compile and run, your map should look like the one below. (see Figure 8).
Figure 8. A map of Europe with the additional borders and capitals layers displayed (Android left, iOS right).
public App() { MapView mapView = new MapView(); mapView.MapUnit = GeographyUnit.DecimalDegree; string baseDataPath = Device.OnPlatform<string>("", "/mnt/sdcard/Android.Sample/", ""); WorldMapKitOverlay worldMapKitOverlay = new WorldMapKitOverlay(); mapView.Overlays.Add("WorldMapKit", worldMapKitOverlay); ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/Countries02.shp"); worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/WorldCapitals.shp"); // Similarly, we use the presetPointStyle for cities. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital3; // This setting also applies from ZoomLevel01 to ZoomLevel20, which means city symbols will be rendered in the same style no matter how far we //zoom in or out. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We create a new Layer for labeling the capitals. ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/WorldCapitals.shp"); // We use the preset TextStyle. Here we pass in "CITY_NAME", the name of the field containing the values we want to label the map with. capitalLabelLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.Capital3("CITY_NAME"); capitalLabelLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // Since the map is drawn with tiles, the label needs to draw on the margin to make sure the text is complete after joining the tiles together. // Change the number below (to 0, for example) to better understand how this works. capitalLabelLayer.DrawingMarginPercentage = 50; LayerOverlay layerOverlay = new LayerOverlay(); layerOverlay.Layers.Add(worldLayer); layerOverlay.Layers.Add(capitalLayer); layerOverlay.Layers.Add(capitalLabelLayer); mapView.Overlays.Add(layerOverlay); mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26); MainPage = new ContentPage { Content = new StackLayout() { Children = { mapView } } }; }
If you compile and run, your map should look like the one below. (see Figure 9).
Figure 9. Europe map with TextStyle applied (Android left, iOS right).
public App() { MapView mapView = new MapView(); mapView.MapUnit = GeographyUnit.DecimalDegree; string baseDataPath = Device.OnPlatform<string>("", "/mnt/sdcard/Android.Sample/", ""); WorldMapKitOverlay worldMapKitOverlay = new WorldMapKitOverlay(); mapView.Overlays.Add("WorldMapKit", worldMapKitOverlay); ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/Countries02.shp"); worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/WorldCapitals.shp"); // We can customize our own Style. Here we pass in a color and a size. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 7, GeoColor.StandardColors.Brown); // The Style we set here is available from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, it will no longer be visible. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; capitalLayer.ZoomLevelSet.ZoomLevel06.DefaultPointStyle = PointStyles.Capital3; // The Style we set here is available from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, it will no longer be visible. capitalLayer.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/WorldCapitals.shp"); // We can customize our own TextStyle. Here we pass in the font, size, style and color. capitalLabelLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.CreateSimpleTextStyle("CITY_NAME", "Arial", 8, DrawingFontStyles.Italic, GeoColor.StandardColors.Black, 3, 3); // The TextStyle we set here is available from ZoomLevel01 to ZoomLevel05. capitalLabelLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; capitalLabelLayer.ZoomLevelSet.ZoomLevel06.DefaultTextStyle = TextStyles.Capital3("CITY_NAME"); // The TextStyle we set here is available from ZoomLevel06 to ZoomLevel20. capitalLabelLayer.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; capitalLabelLayer.DrawingMarginPercentage = 50; LayerOverlay layerOverlay = new LayerOverlay(); layerOverlay.Layers.Add(worldLayer); layerOverlay.Layers.Add(capitalLayer); layerOverlay.Layers.Add(capitalLabelLayer); mapView.Overlays.Add(layerOverlay); mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26); MainPage = new ContentPage { Content = new StackLayout() { Children = { mapView } } }; }
Can you imagine what the map will look like now? Below is the result. If you compile and run, at first it looks like Figure 14, then like Figure 15 as you zoom in further.
Figure 10. Map of Europe before zooming in (Android left, iOS right).
Figure 11. Map of Europe after zooming in (Android left, iOS right).
