In this sample, we show how to create a customized raster layer loading multiple files. In this project, we create the MultipleJpeg2000RasterLayer inherit from Layer to load multiple .jp2 files,and you can use the world files or a RectangleShape which is the extent of the image in world coordinate. You can apply this manner to other file layer.
