map_suite_wpf_desktop_edition_zooming_panning_moving_samples
Map Suite Wpf Desktop Edition Zooming Panning Moving Samples
Center Map Based On Lat/Long
Centering Map with Tolerance
GetZoomLevel
Map Scales
Raster Layer with extent
Restricting Extent
Map Rotation and Multi Touch(WPF)
Zoom In To Feature
Zoom In To Point
Zoom Levels Partitioning
Zoom to Full Extent (WPF)
ClusterPoint (WPF)
The ClusterPointStyle is Integrated into the Map Suite. In this project, you will see how to use the ClusterPointStyle for clustering various features into one. Sometimes, the map may have many features stacked on top of each other at high zoom levels making the map too busy and difficult to read. Clustering is a usefull technique in those situation making the map more readable. It groups together various features into one symbol with the count of all the features being labeled.
It has the higher performance than the before one, create by the customer in this wiki.
</div>
Centering and Rotating
Custom Zoom Levels
Zoom to Full extent
Map Suite License File Generator
map_suite_wpf_desktop_edition_zooming_panning_moving_samples.1464335837.txt.gz · Last modified: 2016/05/27 07:57 by tgwikiupdate
