map_suite_wpf_desktop_edition_vehicle_tracking_samples
Map_Suite_Wpf_Desktop_Edition_Vehicle_Tracking_Samples
Screenshot width=78Sample width=66Product Description
map_suite_wpf_desktop_edition_sample_bread_crumb_trail.jpg View Source
C# Download
Need it in another language?
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ An early project of the Code Community, “Vehicle Direction”, showed how to rotate the icon of a moving vehicle based on the direction. In today’s project, we are going one step further and we are showing how to display dynamically a bread crumb trail as a trailing tail behind the moving vehicle. For this purpose, we are creating a new LineShape with the latest points at every new position.
Centering And Rotating WPF
map_suite_wpf_desktop_edition_sample_centeringandrotatingwpf.jpg View Source
C# Download
Wpf \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Wpf \\ This project is the Wpf version of the services edition sample “Centering and Rotating On Moving Feature”, where we learn how to have the map always centered and rotated based on the location and direction of a moving vehicle. This issues addresses some issues you have to be aware of regarding both ShapeFileFeatureLayer and InMemoryFeatureLayer when applying rotation to the map.
Centering Map with Tolerance
map_suite_wpf_desktop_edition_sample_centering_map_with_tolerance.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the previous project, we showed how to center the map on a moving vehicle. While this is great, it has the disadvantage of having to refresh the map each time the vehicle changes position. In this project, we respond to this inconvenience by using a set tolerance used for determining if the map needs to be refreshed or not. If the vehicle moves within a rectangle of a certain size located in the center of the current extent of the map, the map will not refresh and only the moving vehicle will. If it moves outside the tolerance area, the entire map will be refreshed and the tolerance recalculated.
Detect GPS
map_suite_wpf_desktop_edition_sample_detect_gps.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ Upon request of our users, today we publish a project that is the Desktop version of “Detect GPS” for Web. Notice how we use ValueStyle and change the column value of the feature based on the Spatial Query feature at each new position. We chose this structure so that you can have more flexibility for adding more than one moving vehicle features to the InMemoryFeatureLayer. For that, you can pretty much keep the same code and just add an outer loop for looping thru all the moving features.
Moving Vehicle with Label
View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ As many of the Map Suite developers build applications with the common task of tracking vehicles, in today’s project we show how to update the label of a moving vehicle. The InMemoryFeatureLayer has all the tools necessary to display and label dynamically with editing a moving feature. In today’s project we show in a label the changing Longitude and Latitude each time the vehicle position is updated.
Traveling Salesman Problem
map_suite_wpf_desktop_edition_sample_traveling_salesman_problem.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In today’s project, we are seeing a variant of the sample “Traveling Salesman Problem” of the “How Do I” samples of the Routing product. At the request of a Discussion Forum user, we added a new API to the GetRouteViaVisitStops function where now you can have distinct start and end points. For being able to run this app, you will need the version 3.1.427.0 or later.
Vehicle Direction
map_suite_wpf_desktop_edition_sample_vehicle_direction.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This project is similar to RotatedImageStyle project, but shows in more detail how to use RotatedImageStyle with the Desktop edition. You will see the technique on how to use the Desktop specific OverLays collection to update each Layer. This project forms a good foundation for displaying moving vehicles on a Desktop application.
map_suite_services_edition_vehicle_tracking_samples
map_suite_wpf_desktop_edition_vehicle_tracking_samples.1440040124.txt.gz · Last modified: 2015/09/08 02:51 (external edit)
