This WPF project shows how to get a route between 2 adjacent roads even if they don't intersect within an allowable tolerance. It’s based on Map Suite Geometry Topology module and does not require the Map Suite Routing Extension.
Note: This sample requires MapSuiteCore.dll newer than Daily development build version 9.0.178.0 or Daily Production Build version 9.0.0.178.
In this Wpf sample is on the same theme as the previous sample WrapDatelineMode. Here we show how to take advantage of the projection class WrapDatelineProjection for doing spatial query when on a “virtual map”. From this spatial query example, the developer should understand how the same principle using the same projection class can be applied for other operations such as Spatial Queries, Identify etc. In order to run this sample, you will need the latest Dev Daily Build for Wpf with references to MapSuiteCore.dll and WpfDesktopEdition.dll.
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinate needs to be set so that the feature get selected within a constant distance in screen coordinate to where the user clicked on regardless on the zoom level. This project will show how to accomplish that task regardless of the layer type (polygon, line or point based) and the zoom level of the current extent of the map. This is a Desktop project.
From the Performance Guide:
