map_suite_wpf_desktop_edition_spatial_functions_samples
Map Suite Wpf Desktop Edition Spatial Functions Samples
AjacentRoadSearch
This Wpf project shows how to find a routing from one location to the other location between two adjoin lines. You will need to get in the Dev Daily Build the latest MapSuiteCore.dll and WpfDesktopEdition.dll as references as the GetIntersection API for line based shapes was updated.
Clipping On Line Layer
Create Inner Ring
Distance Query on WrapDatelineMode
In this Wpf sample is on the same theme as the previous sample WrapDatelineMode. Here we show how to take advantage of the projection class WrapDatelineProjection for doing spatial query when on a “virtual map”. From this spatial query example, the developer should understand how the same principle using the same projection class can be applied for other operations such as Spatial Queries, Identify etc. In order to run this sample, you will need the latest Dev Daily Build for Wpf with references to MapSuiteCore.dll and WpfDesktopEdition.dll.
FeatureIdsToExclude
Get Feature Clicked On(Desktop)
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinate needs to be set so that the feature get selected within a constant distance in screen coordinate to where the user clicked on regardless on the zoom level. This project will show how to accomplish that task regardless of the layer type (polygon, line or point based) and the zoom level of the current extent of the map. This is a Desktop project.
Intersect Line
Polygon Shapes To Multipolygon Shapes
Shortest Line Between Two Features with Split
Sweep Angle Desktop
Clipping
Convex Hull
Correcting Nodes
Create Polygon Programatically
Dissolve on Shapefile
Draw a Pie shape
Dynamic Segmentation
Get Feature Clicked On With Projection
Identify Point with Icon
Inner Ring Containment
Intersecting Multi Polygon
Intersecting Two Layers
Merge Line Layers
Merge Point Layers
Merging Layers
Multi Ring Buffering
LEAD Technologies Inc. V1.01
Negative Buffering
Offset Point at Right Angle
Register Shape
Remove LineShape
Spatial Join
Split Polygon
Split Polygon Based On Grid
From the Performance Guide:
Split Polygon Dynamically into Grids based on the Area
Sweep Angle
Splitting Polygons with a Line
map_suite_wpf_desktop_edition_spatial_functions_samples.1450419292.txt.gz · Last modified: 2015/12/18 06:14 by tgwikiupdate
