map_suite_wpf_desktop_edition_spatial_functions_samples
Map Suite Wpf Desktop Edition Spatial Functions Samples
Clipping On Line Layer
Create Inner Ring
Distance Query on WrapDatelineMode
Applies To: Wpf
In this Wpf sample is on the same theme as the previous sample WrapDatelineMode. Here we show how to take advantage of the projection class WrapDatelineProjection for doing spatial query when on a “virtual map”. From this spatial query example, the developer should understand how the same principle using the same projection class can be applied for other operations such as Spatial Queries, Identify etc. In order to run this sample, you will need the latest Dev Daily Build for Wpf with references to MapSuiteCore.dll and WpfDesktopEdition.dll.
FeatureIdsToExclude
Get Feature Clicked On(Desktop)
Applies To: Desktop \ Wpf
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinate needs to be set so that the feature get selected within a constant distance in screen coordinate to where the user clicked on regardless on the zoom level. This project will show how to accomplish that task regardless of the layer type (polygon, line or point based) and the zoom level of the current extent of the map. This is a Desktop project.
Intersect Line
Polygon Shapes To Multipolygon Shapes
Shortest Line Between Two Features with Split
Applies To: Desktop \ Web \ MVC \ Silverlight \ Services \ WPF
This sample will show you how to find the closest line between two features by using the <tt>GetShortestLineTo</tt> API and how to split a line at a given point using the <tt>GetLineOnALine</tt> API. These APIs can be very useful when doing spatial analysis and editing of features. This sample also allows you to dynamically alter the test features using the <tt>EditOverlay</tt> so you can try out different scenarios and see the results quickly. A MapShapes layer is used to display and style the individual results.
Sweep Angle Desktop
map_suite_wpf_desktop_edition_spatial_functions_samples.1441678921.txt.gz · Last modified: 2015/09/08 02:22 by admin
