The purpose of this guide is to help you get started quickly to building your own spatially aware applications. Like any new software, there is some learning to be done.
Before we get started, make sure that you have installed the ThinkGeo Product Center and that you have either started an evaluation or activated a full license of Map Suite WPF Desktop Edition. By default, this will install the Map Suite WPF Desktop Edition 9.0 assemblies to <kbd>C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite WPF Desktop</kbd>.
Let's start with a new WPF project in Microsoft Visual Studio (2010 or newer) and call it HelloWorld (see Figure 1). We can create the project with .NET Framework 4.0 or 4.5.
QSG_WPFDesktop_Img01.png|Figure 1. Creating a new project in the Visual Studio IDE.
The project HelloWorld is created in a new solution called HelloWorld. The wizard creates a single WPF Application.
Next we need to put a Map control on the Form from our Toolbox. The Map control is located on the Toolbox (see Figure 2). If you do not see these controls, you will need to add them to your Toolbox manually.
1. When you first open Visual Studio after installing Map Suite, you may not see the controls in the Toolbox. You will need to follow these steps to add the controls.
Hover on Toolbox and right click anywhere on list of controls. You will get a pop-up menu. Choose “Choose Items…”.
2. A dialogue box to Choose Toolbox Items will appear. You will need to select the WPF Components tab and then click the Browse button. Finally, navigate to the <kbd>C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Wpf Desktop\Current Version\Managed Assemblies</kbd> folder and select the “WpfDesktopEdition.dll”.
3. You should now have the Map Control available in your Toolbox as shown in Figure 2 below.
QSG_WPFDesktop_Img04.png|Figure 2. The Map Controls under the Toolbox window.
We need to add MapSuiteCore.dll to the reference. Right-click the project in Solution Explorer and select “Add Reference…”, navigate to the <kbd>C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Wpf Desktop\Current Version\Managed Assemblies</kbd> folder and select “MapSuiteCore.dll”.
Draw the Map control on the form by clicking on the Map Control object in the Toolbox and then dragging and dropping (using the left mouse button) to the form. You can change its size by modifying the corresponding XAML file, or simply leave the width and height blank to auto fit to its parent. Also, you can leave the name of the Map control as “wpfMap1”. Our map will display in it.
Now that we have our “MapSuiteCore.dll” referenced and a Map Control added, we are ready for adding the code.
After this section, you will be able to draw a map with the MapControl using your own data. At the very beginning, let's have a look at the data and the important objects we will use.
Map Suite WPF Desktop Edition 9.0 supports multiple kinds of data sources, such as SQL Server 2008, Postgre, Oracle, etc. Here we will provide an introduction to Shapefiles which we will use in this Quick Start Guide.
A Map object is the highest level object that encompasses layers and some other objects. For now, you can think of a Map as a set of layers, which can render each layer and present you with a map based on actions performed, such as moving in and out, or panning across the surface to view another part of the map.
Shapefiles provide the data, but Styles are the way you color and draw them. You can specify the color of the country, the width of a road, the shape (triangle, circle, cross etc) of a point, and so on.
Map Suite has many preset Styles built in, including predefined Styles for roads, rivers, cities, countries, and more. This makes it easier to create great looking maps without a lot of hassle.
PresetZoomLevels has a very useful property called
ZoomLevel.ApplyUntilZoomLevel
, which you can very easily use to extend your ZoomLevels. Let's say you want a particular Style to be visible at ZoomLevel03 through ZoomLevel10. To make that work, we can simply code as follows:
<source lang=“csharp”> capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 7, GeoColor.StandardColors.Brown); capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; </source>
In creating our “Hello World” sample application, our first step is to set references to the
MapSuite.Core
and
MapSuite.WpfDesktopEdition
workspaces at the very top of our code, as we will use many classes within them. We do this so that we do not have to use the fully qualified name of the Map Suite classes throughout our code. Setting a reference to the Map Suite workspace can be done in the “code-behind” of the Form by selecting the Form and hitting the F7 function key. Set the reference like this:
<source lang=“csharp”> using ThinkGeo.MapSuite.Core; using ThinkGeo.MapSuite.WpfDesktopEdition; </source> Now let's look at a code sample to bring this concept to fruition. We'll look at Shapefiles relating to the entire world. In our example, we have one such Shapefile:
*The borders of every country in the world (Countries02.shp)
Our next step is to define and add our Layers. Here is the code to use for our example. All of the following code can be placed in the
Window_Loaded
event of the window.
<source lang=“csharp”> private void Window_Loaded(object sender, RoutedEventArgs e) {
<nowiki>//</nowiki> Set the Map Unit. The reason for setting it to DecimalDegrees is that is what the shapefile’s unit of measure is inherently in. wpfMap1.MapUnit = GeographyUnit.DecimalDegree;
<nowiki>//</nowiki> We create a new Layer and pass the path to a Shapefile into its constructor. ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"../../AppData/Countries02.shp");
<nowiki>//</nowiki> Set the worldLayer with a preset Style, as AreaStyles.Country1 has YellowGreen background and black border, our worldLayer will have the same render style. worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1;
<nowiki>//</nowiki> This setting will apply from ZoonLevel01 to ZoomLevel20, that means we can see the world the same style with ZoomLevel01 all the time no matter how far we zoom out/in. worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
<nowiki>//</nowiki> Create a new Layer Overlay to hold the layer we just created LayerOverlay layerOverlay = new LayerOverlay();
<nowiki>//</nowiki> Add a background Layer layerOverlay.Layers.Add(new BackgroundLayer(new GeoSolidBrush(GeoColor.GeographicColors.ShallowOcean))); <nowiki>//</nowiki> Add the shapefile layer to the layer overlay layerOverlay.Layers.Add(worldLayer);
<nowiki>//</nowiki> We need to add the layerOverlay to map. wpfMap1.Overlays.Add(layerOverlay);
<nowiki>//</nowiki> Set a proper extent for the Map. wpfMap1.CurrentExtent = new RectangleShape(0, 78, 30, 26);
<nowiki>//</nowiki> We now need to call the Refresh() method of the Map control so that the Map can redraw based on the data that has been provided. wpfMap1.Refresh();
} </source>
If you compile and run what you have now, your map should look like the one below. (see Figure 4).
QSG_WPFDesktop_Img08.png|Figure 4. A Simple map of Europe.
NOTE: It is important that the
MapUnit
property of a Map object be set using the
GeographyUnit
Enumeration. This is because Shapefiles only store binary vector coordinates, which can be in DecimalDegree, feet, meters, etc., and our map has no idea about what the unit of measurement is until we set it. This information is normally found somewhere in the documentation or within the supplemental data file as discussed in the section on Shapefiles.
#The borders of every country in the world (“Countries02.shp”) #The capitals of the world countries (“WorldCapitals.shp”)
ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"../../AppData/Countries02.shp"); worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(@"../../AppData/WorldCapitals.shp"); <nowiki>//</nowiki> Similarly, we use the presetPointStyle for cities. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital3; <nowiki>//</nowiki> This setting also applies from ZoonLevel01 to ZoomLevel20, that means we can see city symbols the same style with ZoomLevel01 all the time. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
LayerOverlay layerOverlay = new LayerOverlay(); layerOverlay.Layers.Add(new BackgroundLayer(new GeoSolidBrush(GeoColor.GeographicColors.ShallowOcean))); layerOverlay.Layers.Add(worldLayer); <nowiki>//</nowiki> We need to add both of the new layers to the Layer OverLay. layerOverlay.Layers.Add(capitalLayer);
wpfMap1.Overlays.Add(layerOverlay); wpfMap1.CurrentExtent = new RectangleShape(0, 78, 30, 26);
wpfMap1.Refresh();
} </source>
QSG_WPFDesktop_Img09.png|Figure 5. Europe map with 2 layers.
TextStyles are used to label items on the map. As every Shapefile has a relative .dbf file, which includes descriptions for every record, the most common way to use TextStyles is for labeling. For example, the WorldCapitals Shapefile's corresponding .dbf file contains the field “CITY_NAME”. We can use this field to label the cities on our map.
<nowiki>//</nowiki> We create a new Layer for labeling the capitals.
ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(@"../../AppData/WorldCapitals.shp");
<nowiki>//</nowiki> We use the preset TextStyle. Here we passed in the “CITY_NAME”, which is the name of the field we want to label on map.
<nowiki>//</nowiki> As the map is drawn by tiles, it needs to draw on the margin to make sure the text is complete after we joining the tiles together.
<nowiki>//</nowiki> Change the number to another one (for example 0) and you can see the difference expecially when panning.
LayerOverlay layerOverlay = new LayerOverlay(); layerOverlay.Layers.Add(new BackgroundLayer(new GeoSolidBrush(GeoColor.GeographicColors.ShallowOcean))); layerOverlay.Layers.Add(worldLayer); layerOverlay.Layers.Add(capitalLayer); layerOverlay.Layers.Add(capitalLabelLayer);
wpfMap1.Overlays.Add(layerOverlay); wpfMap1.CurrentExtent = new RectangleShape(0, 78, 30, 26); wpfMap1.Refresh();
} </source>
The result is as following (Figure 6):
QSG_WPFDesktop_Img11.png|Figure 6. Europe map with TextStyle.
ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(@"../../AppData/WorldCapitals.shp"); <nowiki>//</nowiki> We can customize our own Style. Here we passed in a color and a size. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 7, GeoColor.StandardColors.Brown); <nowiki>//</nowiki> The Style we set here is available from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, the appearance we set here will not be visible anymore. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05;
capitalLayer.ZoomLevelSet.ZoomLevel06.DefaultPointStyle = PointStyles.Capital3; <nowiki>//</nowiki> The Style we set here is available from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, the appearance we set here will not be visible any more. capitalLayer.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
<nowiki>//</nowiki> We can customize our own TextStyle. Here we passed in the font, the size, the style and the color.
<nowiki>//</nowiki> The TextStyle we set here is available from ZoomLevel01 to ZoomLevel05.
<nowiki>//</nowiki> The TextStyle we set here is available from ZoomLevel06 to ZoomLevel20.
} </source>
Can you imagine what the map will look like now? Below is the result. At first it appears like figure 7, and the map changes to figure 8 as you zoom in.
QSG_WPFDesktop_Img12.png|Figure 7. Europe Map with two ZoomLevels, before Zoom In.
QSG_WPFDesktop_Img13.png|Figure 8. Europe Map with two ZoomLevels, after Zoom In.
Because Desktop Edition uses multi-threading internally for drawing, if you want to change an overlay after the map is initialized, you need to lock the overlay first to avoid threading conflicts. For more information, please have a look at our “How Do I?” sample applications that come with the product.
You now know the basics of using the Map Suite Map control and are able to get started adding functionality into your own applications. Let's recap what we have learned about the object relationships and how the pieces of Map Suite work together:
#It is of the utmost importance that the units (feet, meters, decimal degrees, etc.) be set properly for the Map control based on the data. #Shapefiles provide the data used by a Map control to render a map. #A Map is the basic control that contains all of the other objects that are used to tell how the map is to be rendered. #A Map has one-to-many Layers. A Layer correlates one-to-one with a shape file (.shp). #A Layer can have one-to-many ZoomLevels. ZoomLevels help to define ranges (upper and lower) of when a Layer should be shown or hidden.
<br> filelinkDownload Sample Code From This Exercise (1.5 MB)
