View Source |
View Source |
View Source |
Applies To: Wpf
In this Wpf sample is on the same theme as the previous sample WrapDatelineMode. Here we show how to take advantage of the projection class WrapDatelineProjection for doing spatial query when on a “virtual map”. From this spatial query example, the developer should understand how the same principle using the same projection class can be applied for other operations such as Spatial Queries, Identify etc. In order to run this sample, you will need the latest Dev Daily Build for Wpf with references to MapSuiteCore.dll and WpfDesktopEdition.dll.
View Source |
View Source |
View Source |
View Source |
View Source |
Applies To: Wpf
In this Wpf project, we show a new property of Overlay, WrapDatelineMode. When you set this property to WrapDatelineMode.WrapDateline, the overlay will display to the right or left as you continuously pan west or east. This is very useful when dealing with world maps and you want to display the pacific rim as one extent. You have to be aware that this feature comes with some limitations. For example, on the “virtual” maps, the world coordinates are no longer valid and you need a special projection that we created (WrapDatelineProjection) to have the world coordinates displaying correctly. In order to run this sample, you will need the latest Dev Daily Build for Wpf with references to MapSuiteCore.dll and WpfDesktopEdition.dll.
View Source |
Applies To: MVC \ Desktop \ Web \ Silverlight \ Services \ Wpf
View Source |
View Source |
