map_suite_wpf_desktop_edition_layers_featuresources_samples
Map Suite Wpf Desktop Edition Layers & FeatureSources Samples
ENC Viewer for displaying S-57 (*.000) File
Native KML(Keyhole Markup Language) Support
In today's WPF project, we show you how to take advantage of Map Suite to load the Keyhole Markup Language (KML) file, which is an XML notation for expressing geographic annotation and visualization within Internet-based brwosers. With the latest KML support in Map Suite, you can eaisily display such files on a Map Suite control, including adorment pictures, placemarks etc. Also you can do the conversion between KML and any other vector formats supported by Map Suite componenets.
Apply Quick Filter to FeatureSource
In today's WPF project, we show you how to apply the quick filters to a FeatureSource with the help of LinkSource and LinkExpressions. With the LinkExpreesion, we can specify the query string to determine which features will be displayed. This feature can be applied in all Map Suite products.
NOAA Global Weather Station
In today's WPF project, we show you how to query and display real time NOAA wather station data directly as a Layer, which allows you to display up-to-date weather station data from around the world on top of your maps. The weather station data is sourced from NOAA and is refreshed every 15 minutes in the background. As these classes are inherited from the FeatureSource and FeatureLayer, many properties are querable and can be used to create a variety of maps or analysis of current weather patterns. This feature can be applied in all Map Suite products.
Magnetic Declination
In today's WPF project, we show you how to add the Magnetic Declination or Magnetic variation to the map, it's designed as an AdormentLayer, which is used for showing the angle on the horizontal plane between magnetic north (the direction in which the north end of a compass needle, corresponding to the direction of the Earth's magnetic field lines) and true north (the direction along a meridian towards the geographic North Pole). This angle varies depending on one's position on the Earth's surface, and over time. See http://en.wikipedia.org/wiki/Magnetic_declination for more details. This feature can be applied in all Map Suite products.
Delay Map Drawing Feature
In this WPF project, we show you how to use the Delay Map Drawing feature to control whether or not redraw the layer after a specified delay. This option is very helpful for anyone wanting to do something before actually refresh the map, such as editing the elements, adding an animation etc. This effect can be avaible in all Map Suite products.
Combining Overlays
Create GRID
Edit Attribute Of Shapefile
Edit Geometry Of Shapefile
Get Data From Server With WCF
codesamples
Graphic Logo Adornment Layer
Applies To: Desktop \ Services \ Wpf
Heat Map
Highlight at Mouse Hover
Heat Map with earthquakes
Image Stream Loading
KML Extension
Latitude Longitude Graticule
Native TAB File Suppport
Numbered Grid
PopupOverlay
Applies To: Wpf
In this Wpf project, we explore more capabilities of the PopupOverlay and its collection of Popups. With the Content property, we can add a TextBox or any other control to a Popup. For example, here we show how to have the column value of a selected feature appear in a Popup on the user MapClick event. Notice how that column value can be easily changed by typing in the TextBox of the Popup and committing the edit.
Save & Load State
Applies To: Wpf
The purpose of this Wpf project is to show how to use the new SaveState and LoadState of the SimpleMarkerOverlay. We show how you can simply drag the icons to change their location, save their state to a file and then reload the state from that file. For this sample to work, you will need to use the latest production daily build of “MapSuiteCore.dll” and “WpfDesktopEdition.dll”, version 4.0.40.87 or higher. This project applies to Map Suite Wpf Desktop Edition only.
codesamples
WMTS Overlay
codesamples
This project shows how to consume data from a WMTS Server using WmtsOverlay. You would find the code pretty straightforward, while behind the scenes we request tiles from the server asynchronously and efficiently, and stitch them into a proper map.
This class is introduced from version 6.0.187.0, besides this WmtsOverlay, we also have WmtsLayer available. Here is the WMTSLayer Sample.
map_suite_wpf_desktop_edition_layers_featuresources_samples.1441623405.txt.gz · Last modified: 2015/09/07 10:56 by admin
