map_suite_wpf_desktop_edition_labeling_samples
Map Suite Wpf Desktop Edition Labeling Samples
Draggable Labels
Labeling based on size
MultiLine Labeling
Multiple Labels
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “[ColumnName1][ColumnName2]…“ and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
Decimal Degrees Formatting
LEAD Technologies Inc. V1.01
Label to Show Location
Labeling Based On Columns
Multi Column Labeling
map_suite_wpf_desktop_edition_labeling_samples.1443578944.txt.gz · Last modified: 2015/09/30 02:09 by admin
