map_suite_wpf_desktop_edition_labeling_samples
Map Suite Wpf Desktop Edition Labeling Samples ====== Draggable Labels
=78|Sample ^ width=66|Product ^ Description ^
map_suite_wpf_desktop_edition_sample_draggable_labels.jpg View Source
C# Download
Need it in another language?
Wpf \\ \\ Applies To: Web \\ Wpf \\ In this wpf project, we are going to show how to place labels from a shapefile into a SimpleMarkerOverlay. Using the DragMode property of the SimpleMarkerOverlay, the user can then drag the labels to place them at the desired location for the most pleasing labeling effect. This project will be later completed to show how to save the state of the dragged labels from the SimpleMarkerOverlay and reload them.
Labeling based on size
Applies To: Desktop \ Web \ Silverlight \ Services \ Wpf \
MultiLine Labeling
Multiple Labels
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “ColumnName1[ColumnName2]…” and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
map_suite_wpf_desktop_edition_labeling_samples.1441619125.txt.gz · Last modified: 2015/09/07 09:45 by admin
