map_suite_wpf_desktop_edition_interactiveoverlays_samples
Map Suite Wpf Desktop Edition InteractiveOverlays Samples
Canceling TrackOverlay
Applies To: Desktop \\ Services \\ Wpf \\
As with Dynamic Info on TrackShape project, it shows how TrackOverlay can be extended to add some custom functionalities.
You will see how to handle some events of the map such as KeyDown and how to manipulate TrackOverlay.
Custom Track Line
Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\
Custom Track Polygon
Drag Select Vertices As Group
Applies To: Desktop \\ Wpf \\
With EditInteractiveOverlay, we know how to drag a feature such as polygon as a whole. We also know how to drag an individual vertex by setting the appropriate properties. Here we go a little further and we show how to create an inherited class from EditInteractiveOverlay to implement the logic for selecting vertices and dragging them as a group. See how the protected methods MouseDownCore, MouseUpCore, MouseClickCore and MouseMoveCore were overridden for that purpose. This is a Desktop app that also applies to Wpf.
Dragged Point Style
Dragged Point Style Advanced
This project is another example of how extendible EditInteractiveOverlay is for the editing needs of the user. You can see how to change the styles of the vertex being dragged based on the Shift key and have the vertex snap to any feature. Thanks to the protected override functions such as KeyDownCore, KeyUpCore, MouseUpCore and DrawCore, these functionalities can be easily implemented by inheriting from EditInteractiveOverlay.
Dragged PointStyle with Label
In our series of projects dedicated to EditInteractiveOverlay, today you will see how easy it is to add some labeling to your dragged control point showing dynamic information. Here we show how to display the distance from the dragged control point to the closest point of a reference shape. Also, to augment the experience of the user, the closest point of the reference shape is also shown varying as the control point is dragged around.
In the GIS field, enterprises have different needs on how they edit there data and on how smooth the editing should be allowing the maximum control and precision to the technician editing the data. This example on how to use the EditInteractiveOverlay demonstrates how powerful and flexible editing is with Map Suite map control.
Dragging Icon
Dragging Icon Advanced
Dragging Vertex
The purpose of today’s project is not so much as show a new technology as to show an improvement in an existing one. We are already familiar with EditInteractiveOverlay with projects such as “Dragged PointStyle with Label”, “Snap To Layer” and “Snapping to Vertex”. But those projects showed EditInteractiveOverlay on small shapes. Using EditIntercticeOverlay on complex shapes became not very responsive. We improved that and now you can drag, resize, rotate and drag individual vertex of a complex polygon made of thousand of vertices with good responsiveness as you can see in this example.
To run this Desktop project, you will need the version 4.0.66.0 or later of the development daily build for MapSuiteCore and DesktopEdition dlls. And do not forget to add a reference to WindowsBase.dll.
This improvement is currently only in the development branch, it will be added to the production branch at the next major release in November.
Dynamic Info On TrackShapes
codesamples
Applies To: Desktop \\ Web \\ Silverlight \\ Wpf \\
Editing Rectangles
This sample shows how to extend the EditInteractiveOverlay rectangles as shapes rather than polygon shapes by setting special column values. For features (Well Known Text and Binary), the concept of a rectangle is not supported and typically rectangles are handled as polygons. This feature allows users to modify the rectangle but requires that the modification keep a rectangular form. The rectangle doesn't need to be straight as long as all of the corner angles are at 90 degrees relative to each other.
To activate the feature, you need to assign the value of the column called “Edit” to “rectangle”. The resize function will keep the ratio of width and height of the rectangle, otherwise it will use the original method.
http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5822/afv/topic/Default.aspx
EditOverlay Styles
Connecting Two Shapes With Arraw Line Samples
Preset Vertex To Tracked Polygon
Select and Drag(wpf)
Select Vertices
Select with Track Shape
Snap To Layer
Snapping to Layer2
Snapping to Vertex
Track Zoom In Without Shift
codesamples
Tracked Shapes to File
Tracked Shapes to WKT
TrackOverlay with ESC(New)
codesamples
This project is meant to respond to a limitation with aborting tracking a shape in the project TrackOverlay with Esc. Now we can abort the tracked shape from the first vertex being added. Notice how we used a new class CustomTrackInteractiveOverlay inheriting from TrackInteractiveOverlay for this purpose.
Vertex Tolerance
map_suite_wpf_desktop_edition_interactiveoverlays_samples.1441618086.txt.gz · Last modified: 2015/09/07 09:28 by admin
