map_suite_wpf_desktop_edition_features_bug_fixes_change_log
Map Suite Wpf Desktop Edition Features & Bug Fixes Change Log
Version 9.0.0.0
Release date: 06/24/2015
  • Added the new API SetWellKnownBinary(bytemap_suite_wpf_desktop_edition_features_bug_fixes_change_log wkb) to Feature class to allow changing the WKB of the feature.
  • Improved the performance of method bytemap_suite_wpf_desktop_edition_features_bug_fixes_change_log ShapeFile.ReadPolygon(bytemap_suite_wpf_desktop_edition_features_bug_fixes_change_log dataBytes, int startIndex).
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
Version 8.0.0.0
Release date: 06/06/2014
Version 7.0.0.0
Release date: 06/03/2013
Version 6.0.0.0
Release date: 05/14/2012
Version 5.5.0.49
Release date: 12/31/2011
Version 5.5.0.0
Release date: 11/14/2011
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
Version 5.0.0.0
Release date: 5/16/2011
  • Marked Serializable for GeoTiffRasterLayer, HeatLayer, GraticuleAdornmentLayer and HeatStyle.
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Added OSM overlay.
  • Added ClusterPointStyle
Map Suite WPF Desktop Edition Desktop GIS WPF GIS .NET
map_suite_wpf_desktop_edition_features_bug_fixes_change_log.1441683381.txt.gz · Last modified: 2015/09/08 03:36 by admin
