map_suite_wpf_desktop_edition_faq_layers_featuresources
Map Suite Wpf Desktop Edition FAQ_Layers & FeatureSources
How do I efficiently display a subset of a shape file without splitting it?
This sample shows how you can display a subset of a shapefile without splitting the physical shapefile. For example, you may have a single shapefile that contains both highways and local roads. To improve display speed, you may be temped to split it into two separate shapefiles so you can quickly display local roads with one style and highways with another style (and avoid using a value style, which can be slow). But at this project demonstrates, rather than split your shapefile you can simply build two custom indexes, one for each road type. Then, when you create your ShapeFileFeatureLayer, you'll simply use your original shapefile and specify a custom index. Each custom index will limit the records that can be seen by the Layer, making it very fast and efficient.<br> For more information and a real-world example, please see the Map Suite discussion forum post at: Forum Post
How do I display highways and local roads using different symbols from the same shape file?
How do I draw a north arrow on my map?
Sample:Compass
In the project “North Arrow”, you saw how to extend AdornmentLayer to create a North Arrow AdormentLayer. In this project, we expand on that idea and create a more sophisticated class. You will see how you can combine two images to create a compass. Compare to “North Arrow” project, we also added some other handy properties such as a Position property. Also, the compass can be of varied sizes thanks to the SizePercentage property. Finally, if you pass just one image, the compass can behave just like a regular north arrow.<br> We also added new designs of compass in smaller version. See the attached file: Rotating Compass New Smaller Designs.zip.
How do I display graphs and charts on the map?
Sample:Zedgraph
In our “How Do I” apps, there is sample app that shows how to add graphs to the map using the ZedGraph library. In this project, using the same data, the US cities, we elaborate a little bit on the pie chart. You will see how to add some gradient colors to the chart, how to label the different pie slices, how to add a title etc. Zedgraph is a truly massive library for graphics and Pie chart is only one type of chart among many others. As you can add pie charts to your map, you can also add bar charts, trend charts etc. I suggest you check out this site for more info on ZedGraph <br> http://zedgraph.org/wiki/index.php?title=Main_Page<br> With Map Suite, you have the whole ZedGraph API available with an easy interface to add the graphs to the map. <br> For this project, in addition to the MapSuiteCore.dll, you will also need the ZedGraph.dll and ZedGraphStyleExtension.dll references. We will have several projects showing how to integrate other types of charts to your map.
How do I add a watermark to the map?
How do I encrypt a shape file for security?
Sample:Shapefile Encryption
How do I get geometry data from the server using WCF in Silverlight?
How do I display a scale bar using custom units?
Sample:Scale Bar
How can I show my own logo on the map?
Sample:Graphic Logo Adornment Layer
How do I display heat map?
Sample:Heat Map
How can I load an image from a stream rather than a file?
Sample:Image Stream Loading
How can I draw KML on the map?
Sample:KML Extension
How do I display latitude and longitude graticule lines?
How can I display a legend on my map?
Sample:Legend Adornment Layer
How do I show a mini map?
How do I display multi geo-raster files as one layer?
Sample:Multi Geo Raster Layer
How do I work with multi index files?
Sample:Multi Index
How do I display point data from an OLE DB complied data source?
This project shows the power of MapSuite by giving to the developer the possibility to create its own layer based on an existing format containing spatial information. If the developer is familiar with a certain format like oledb, he can create its own FeatureSource reading the database and its own FeatureLayer wrapping the FeatureSource and providing the drawing logic.<br> In this project, we create the class OledbPointFeatureSource inheriting from FeatureSource and OledbPointFeatureLayer inheriting from FeatureSource.
How do I draw a north facing arrow when using rotation?
Sample:North Arrow
Displaying the North Arrow:
How do I create a numbered grid for a given extent?
Sample:Numbered Grid
How to use a common FeatureSource for two different Overlays?
Sample:Combining Overlays
How to edit the geometry of a shapefile?
How to edit attribute of a shapefile?
How to create GRID?
Sample:Create GRID
Sample:Isolines
Yes. Starting with build 5.0.87.0 of Map Suite, you can add isolines to your applications with Map Suite – please see the code sample linked above. For the uninitiated, isolines are a way to visualize breaks between different groups of data such as elevation levels, soil properties, or just about anything else you can imagine. The above code sample also shows the various steps in creating isolines, including the gathering of point data, creating a grid using interpolation, and finally, picking your isoline break levels. We also quickly dive into some more advanced options such as generating isolines on the fly. To bring this all together, check out our [[Media:ServicesEditionSample_Isolines_110809.wmv|instructional video]] that will walk you through the process of setting up and working with isolines in Map Suite.
map_suite_wpf_desktop_edition_faq_layers_featuresources.1441683675.txt.gz · Last modified: 2015/09/08 03:41 by admin
