map_suite_wpf_desktop_edition_all_samples
Table of Contents
Map Suite Wpf Desktop Edition All Samples
Map Suite Wpf Desktop Edition How Do I Samples
The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples. Available in both C# and VB.NET, these samples are designed to hit all the highlights of Map Suite, from simply adding a layer to a map to performing spatial queries and applying a thematic style. Consider this collection your “encyclopedia” of all the Map Suite basics and a great starting place for new users.
GPS to Google Map(Desktop)
Today we have the Desktop version of the Web project “GPS to Google”. In this project, we show how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
Great Circle with Google Map
Mini map with Google Map
OpenStreetMap
ArcGISServerRestLayer
In this wpf-based project, we'll demonstrate the new ArcGISServerRestLayer released with Map Suite 9.0. This layer gives developers a simple and powerful tool to access their maps that reside on ArcGIS Server. This new layer utilizes the ArcGIS Server REST API. Now, the latest version of Map Suite Core can support that. In order to run this project, you will need the Development Build 9.0.443.0 or later.
Shapefile to Google Map
Get Features From ArcGISServer
In this wpf-based project, it illustrates how to get the features from the ArcGIS Restful Server. On the left side of the screenshot shows the raster data from ArcGIS Server and on the other side shows the features from ArcGIS Restful Server. In order to run this project, you will need the Development Build 9.0.482.0 or later.
Canceling TrackOverlay
As with Dynamic Info on TrackShape project, it shows how TrackOverlay can be extended to add some custom functionalities.
You will see how to handle some events of the map such as KeyDown and how to manipulate TrackOverlay.
Custom Track Line
Custom Track Polygon
Drag Select Vertices As Group
With EditInteractiveOverlay, we know how to drag a feature such as polygon as a whole. We also know how to drag an individual vertex by setting the appropriate properties. Here we go a little further and we show how to create an inherited class from EditInteractiveOverlay to implement the logic for selecting vertices and dragging them as a group. See how the protected methods MouseDownCore, MouseUpCore, MouseClickCore and MouseMoveCore were overridden for that purpose. This is a Desktop app that also applies to Wpf.
Dragged Point Style
Dragged Point Style Advanced
This project is another example of how extendible EditInteractiveOverlay is for the editing needs of the user. You can see how to change the styles of the vertex being dragged based on the Shift key and have the vertex snap to any feature. Thanks to the protected override functions such as KeyDownCore, KeyUpCore, MouseUpCore and DrawCore, these functionalities can be easily implemented by inheriting from EditInteractiveOverlay.
Dragged PointStyle with Label
In our series of projects dedicated to EditInteractiveOverlay, today you will see how easy it is to add some labeling to your dragged control point showing dynamic information. Here we show how to display the distance from the dragged control point to the closest point of a reference shape. Also, to augment the experience of the user, the closest point of the reference shape is also shown varying as the control point is dragged around.
In the GIS field, enterprises have different needs on how they edit there data and on how smooth the editing should be allowing the maximum control and precision to the technician editing the data. This example on how to use the EditInteractiveOverlay demonstrates how powerful and flexible editing is with Map Suite map control.
Dragging Icon
Dragging Icon Advanced
Dragging Vertex
The purpose of today’s project is not so much as show a new technology as to show an improvement in an existing one. We are already familiar with EditInteractiveOverlay with projects such as “Dragged PointStyle with Label”, “Snap To Layer” and “Snapping to Vertex”. But those projects showed EditInteractiveOverlay on small shapes. Using EditIntercticeOverlay on complex shapes became not very responsive. We improved that and now you can drag, resize, rotate and drag individual vertex of a complex polygon made of thousand of vertices with good responsiveness as you can see in this example.
To run this Desktop project, you will need the version 4.0.66.0 or later of the development daily build for MapSuiteCore and DesktopEdition dlls. And do not forget to add a reference to WindowsBase.dll.
This improvement is currently only in the development branch, it will be added to the production branch at the next major release in November.
Dynamic Info On TrackShapes
Editing Rectangles
This sample shows how to extend the EditInteractiveOverlay rectangles as shapes rather than polygon shapes by setting special column values. For features (Well Known Text and Binary), the concept of a rectangle is not supported and typically rectangles are handled as polygons. This feature allows users to modify the rectangle but requires that the modification keep a rectangular form. The rectangle doesn't need to be straight as long as all of the corner angles are at 90 degrees relative to each other.
To activate the feature, you need to assign the value of the column called “Edit” to “rectangle”. The resize function will keep the ratio of width and height of the rectangle, otherwise it will use the original method.
http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5822/afv/topic/Default.aspx
EditOverlay Styles
Connecting Two Shapes With Arraw Line Samples
Preset Vertex To Tracked Polygon
Select and Drag(wpf)
Select Vertices
Select with Track Shape
Snap To Layer
Snapping to Layer2
Snapping to Vertex
Track Zoom In Without Shift
Tracked Shapes to File
Tracked Shapes to WKT
TrackOverlay with ESC(New)
This project is meant to respond to a limitation with aborting tracking a shape in the project TrackOverlay with Esc. Now we can abort the tracked shape from the first vertex being added. Notice how we used a new class CustomTrackInteractiveOverlay inheriting from TrackInteractiveOverlay for this purpose.
Vertex Tolerance
Draggable Labels
Labeling based on size
MultiLine Labeling
Multiple Labels
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “[ColumnName1][ColumnName2]…“ and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
Decimal Degrees Formatting
LEAD Technologies Inc. V1.01
Label to Show Location
Labeling Based On Columns
Multi Column Labeling
Custom Scale Bar
Draw Custom Exception
MDI Form
Topology Validation
Use Map with MVC Framework
ShapeFile to SQLite Convertion Tool
This sample demonstrates how to save the features in a shape file (.shp) into a Sqlite file (.sqlite) for a higher query performance. This takes the built-in functionalities of recent daily builds after 9.0.0.1/9.0.1.0 or later, which you can download from the ThinkGeo Customer Portal or Map Suite Product Center.
Indexed Raster Layer
This sample shows how to create indexed raster layer. The sample supports rTree index file and create it if not exist. It is high performance for multiple raster layers.
Finding Nearest Cross Streets
Labeling Flight Lines
This sample shows how to offset arc shaped flight lines so multiple from point to point are visible and then show popup labels providing information on the flights the lines represent.
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
<div sample_otherlinks> [
Large Scale Map Printing
This WPF project is the second in our series of samples on printing. The first introductory sample served as a presentation of the different printing concepts such as page layout, the map element, legends, titles, data grids, logos and the user's interaction with them. Using all of the printing tools we introduced in the first sample, here we will demonstrate a real-world print scenario at a large scale with data for parcels at a county level. By reading the descriptive comments within the sample code itself, you will better understand how to handle your printing needs and follow cartographic standards for map presentation.
Map Printing With High Quality
This WPF project is the 3rd sample on the printing series. It demonstrates how to print your maps in high quality. This new feature for Map Suite is available in version 9.0.483.0 or later. From the sample you will better understand how to use DPI for handling print quality. The sample is based on raster images, but could also be used with vector data.
screenshot
Custom Parameters Projection
Custom Rotation Projection
Distance Query on WrapDatelineMode
In this Wpf sample is on the same theme as the previous sample WrapDatelineMode. Here we show how to take advantage of the projection class WrapDatelineProjection for doing spatial query when on a “virtual map”. From this spatial query example, the developer should understand how the same principle using the same projection class can be applied for other operations such as Spatial Queries, Identify etc. In order to run this sample, you will need the latest Dev Daily Build for Wpf with references to MapSuiteCore.dll and WpfDesktopEdition.dll.
Google Map to Geodetic
Local Datum UTM
Projection by Analyzing Prj File
Projection Distance LineStyle
Wrap Dateline Mode
In this Wpf project, we show a new property of Overlay, WrapDatelineMode. When you set this property to WrapDatelineMode.WrapDateline, the overlay will display to the right or left as you continuously pan west or east. This is very useful when dealing with world maps and you want to display the pacific rim as one extent. You have to be aware that this feature comes with some limitations. For example, on the “virtual” maps, the world coordinates are no longer valid and you need a special projection that we created (WrapDatelineProjection) to have the world coordinates displaying correctly. In order to run this sample, you will need the latest Dev Daily Build for Wpf with references to MapSuiteCore.dll and WpfDesktopEdition.dll.
Graticule with Projection
Wrap Dateline Mode With Projection
Datum Transformation
Geodetic to State Plane
Geodetic to UTM on the fly
GeoRaster Projection
Measurements Decimal Degrees
Pacific Rim
Polygon across Meridian
Projection Distortion
Projection in Feet
Routing with Projections
Save To Projection
Street Intersection
World Coordinates
This WPF project shows how to get a route between 2 adjacent roads even if they don't intersect within an allowable tolerance. It’s based on Map Suite Geometry Topology module and does not require the Map Suite Routing Extension.
Note: This sample requires MapSuiteCore.dll newer than Daily development build version 9.0.178.0 or Daily Production Build version 9.0.0.178.
Clipping On Line Layer
Create Inner Ring
FeatureIdsToExclude
Get Feature Clicked On(Desktop)
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinate needs to be set so that the feature get selected within a constant distance in screen coordinate to where the user clicked on regardless on the zoom level. This project will show how to accomplish that task regardless of the layer type (polygon, line or point based) and the zoom level of the current extent of the map. This is a Desktop project.
Intersect Line
Polygon Shapes To Multipolygon Shapes
Shortest Line Between Two Features with Split
Sweep Angle Desktop
Clipping
Convex Hull
Correcting Nodes
Create Polygon Programatically
Dissolve on Shapefile
Draw a Pie shape
Dynamic Segmentation
Get Feature Clicked On With Projection
Identify Point with Icon
Inner Ring Containment
Intersecting Multi Polygon
Intersecting Two Layers
Merge Line Layers
Merge Point Layers
Merging Layers
Multi Ring Buffering
Negative Buffering
Offset Point at Right Angle
Register Shape
Remove LineShape
Spatial Join
Split Polygon
Split Polygon Based On Grid
From the Performance Guide:
Split Polygon Dynamically into Grids based on the Area
Sweep Angle
Splitting Polygons with a Line
ClusterPointStyle is integrated into Map Suite's core. In this project you will see how to use the ClusterPointStyle for clustering various features into one. Sometimes, the map may have too many features which are stacked on top of each other making the map illegible at higher zoom levels. Clustering is a useful technique as it allows you to group together various features into one labeled symbol with the count of all the features. This latest sample also includes recent performance enhancements to the clustering API.
Map Suite Wpf Desktop Edition Styles Samples
Filter Style
In today's Wpf project, we show you how to apply the FilterStyle to a layer's display. By using this style, the map will filter the features queried from the source file by checking if a specified column value fits the input condition. This effect can be applied to all the Map Suite products.
Animated Gif
In today’s project, we learn how to extend InMemoryFeatureLayer to have the ability to display animated gif for each layer in the Desktop edition. You will notice that for now, we are limited to have one animated gif per InMemoryFeatureLayer but in the future, we will show the technique to have a different animated gif for each feature of the InMemoryFeatureLayer.
Default ValueStyle
Distance Line Style
EditOverlay Styles
Line Style With Increment
Multiple Dot Density Styles
MultiLine Labeling
Side View Icon
Smooth Transparent Route
Weather Line Style
Weather Line Style
Adjusted Scaling Image Style
Cached Value Style
ClusterPointStyle
Decimal Degrees Formatting
LEAD Technologies Inc. V1.01
Displaying One-Way Streets
Doughnut Point Style
Feature Centric Style
Flashing Point Style
Hybrid TextStyle
Image Style
Isolines
Rotate Icon
Routing Styles
Scaling Image Style
Scaling TextStyle
Scaling TextStyle for Polygon
Sized Point Style
Start End LineStyle
TextStyle for Multi Line
Time Based Point Style
Time Line
ValueStyle with Countries
WordWrapped TextStyle
World Sized Image Style
World Sized Text Style
Label Point with Circle Symbol and Mask Description
Centering And Rotating WPF
Centering Map with Tolerance
Detect GPS
Moving Vehicle with Label
Traveling Salesman Problem
Vehicle Direction
Chemical Plume
Filter Radar Image
Rotated Image Style
Snap GPS to Street
Center Map Based On Lat/Long
GetZoomLevel
Map Scales
Raster Layer with extent
Multiple Jpeg2000 Raster Layer
Restricting Extent
Map Rotation and Multi Touch(WPF)
Zoom In To Feature
Zoom In To Point
Zoom Levels Partitioning
Zoom to Full Extent (WPF)
Custom Zoom Levels
Zoom to Full extent
Map Suite License File Generator
map_suite_wpf_desktop_edition_all_samples.1441604104.txt.gz · Last modified: 2015/09/07 05:35 by admin
