map_suite_world_map_kit_online
Map Suite World Map Kit Online
The page was created before Map Suite 10. Map Suite 10.0 organized many classes into new namespaces and assemblies as well as had a few minor breaks in compatibility. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code check out this(http://wiki.thinkgeo.com/wiki/map_suite_10_upgrade_guide).
The Map Suite World Map Kit Online is a cloud-based map service, offering detailed street, aerial, and hybrid maps of the globe that your applications can consume directly over the Internet. Because ThinkGeo maintains the servers for you, you won't have to worry about distributing huge datasets to your clients. Just add a few lines of code to your application and the entire world is at your fingertips.
Product Guides
  • Quick Start Guide
    This guide helps you get you up to speed with integrating the World Map Kit Online map control into your GIS software.
Demos
You can view an interactive sample of Map Suite World Map Kit here.
Frequently Asked Questions
  • General Questions
    These FAQ's cover general questions about the World Map Kit Online service.
  • Technical Questions
    These FAQ's cover the technical aspects of the World Map Kit Online service.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_world_map_kit_online.1489549675.txt.gz · Last modified: 2017/03/15 03:47 by tgwikiupdate
