map_suite_wms_server_edition_features_bug_fixes_change_log
Map Suite WMS Server Edition Features & Bug Fixes Change Log
Version 9.0.0.0
Release date: 06/24/2015
Version 8.0.0.0
Release date: 06/06/2014
Version 7.0.0.0
Release date: 06/03/2013
  • Added the ClearCache method to MapPrinterLayer to delete the cache image
  • Added the spatial index status cache for MsSql2008FeatureSource
  • Added support of the FileGeoDatabase
  • Added support off write white paper on Printing
  • Added support of the GRD/GRI grid format
Version 6.0.0.0
Release date: 05/14/2012
Version 5.5.0.49
Release date: 12/31/2011
Version 5.5.0.0
Release date: 11/14/2011
  • Added the IsoLine Support.
Version 5.0.0.0
Release date: 5/16/2011
ThinkGeo.MapSuite.WmsServerEdition Namespace:
  • Fixed a bug that occurred when hosting multiple-plugins.
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
ThinkGeo.MapSuite.WmsServerEdition Namespace: *Fixed warning with FxCop *Added VB Samples *Added the two samples missed in last release *Fixed the issue about GetIntersectingCells method of Matrix throws exception *Added TiledWmsLayer and it's RasterSource to support WMS Server Edition *Added Log function using Log4net. *Added SendingTile and SentTile event for TiledWmsLayer *Added signiture for TiledWmsLayer with ClientId and PrivateKey *Improved the rendering performance *Added XML info format support for GetFeatureInfo Request *Added Json info format support for GetFeatureInfo Request
Map Suite WMS Server Edition Web GIS ASP.NET GIS .NET
map_suite_wms_server_edition_features_bug_fixes_change_log.1441867476.txt.gz · Last modified: 2015/09/10 06:44 by admin
