map_suite_windows_phone_edition_styles_samples
Map Suite Windows Phone Edition Styles Samples
Adjusted Scaling Image Style
Cached Value Style
ClusterPointStyle
Decimal Degrees Formatting
LEAD Technologies Inc. V1.01
Default ValueStyle
Displaying One-Way Streets
Distance Line Style
Doughnut Point Style
EditOverlay Styles
Feature Centric Style
Flashing Point Style
Hybrid TextStyle
This project is a follow up to the Discussion Forum post
http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6652/afv/topic/Default.aspx
In this project, we create a new Text Style combining word wrapping that we saw in the project
http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
Line Style With Increment
Multiple Dot Density Styles
MultiLine Labeling
Projection Distance LineStyle
Rotate Icon
Routing Styles
Scaling Image Style
Scaling TextStyle
Scaling TextStyle for Polygon
Side View Icon
Sized Point Style
Smooth Transparent Route
Start End LineStyle
TextStyle for Multi Line
Time Based Point Style
Time Line
ValueStyle with Countries
Weather Line Style
WordWrapped TextStyle
World Sized Image Style
World Sized Text Style
Cached Value Style
ClusterPointStyle
Hybrid TextStyle
Image Style
Isolines
Rotate Icon
Routing Styles
Scaling Image Style
Scaling TextStyle
Sized Point Style
Start End LineStyle
Time Line
Label Point with Circle Symbol and Mask Description
map_suite_windows_phone_edition_styles_samples.1442542042.txt.gz · Last modified: 2015/09/18 02:07 (external edit)
