Need it in another language?
This project is a follow up to the Discussion Forum post
http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6652/afv/topic/Default.aspx
In this project, we create a new Text Style combining word wrapping that we saw in the project
http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
