map_suite_windows_phone_edition_styles_samples
Map_Suite_Windows_Phone_Edition_Styles_Samples
Adjusted Scaling Image Style
Screenshot width=78Sample width=66Product Description
map_suite_silverlight_edition_sample_adjusted_scaling_image_style.jpg View Source
C# Download
Need it in another language?
Services \\ \\ Applies To: WindowsPhone \\ \\ Desktop\\ Web\\ Silverlight \\ Services\\ Wpf\\ The purpose of this project is to address some of the limitations of the ScalingImageStyle that we saw in the project of the same name. As with ScalingImageStyle, with AdjustedScalingImageStyle, you have the icon scaling up and down according to the zoom level; but you can also have the icon pointing correctly to the point feature it represents if for example you are using a pin as an icon. Also, the problem of the height of the image not sizing proportionally to its width has been corrected.
Cached Value Style
no_screenshot.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ The MapSuite API provides a Value Style as you can see in the sample app “Draw features based on value”. This is a great way to display feature features based on some value of a column. With this style and any other styles offered by the MapSuite API, each time the map has to redraw the value for each feature within the current extent has to be fetched. This can affect the performance especially if a large number of features are used. With CachedValueStyle, the value for each feature is cached into memory to reduce the overhead of having to go and fetch the value for each feature each time the map has to draw. Using this CachedValueStyle has a benefit on performance but you need to pay attention on memory usage.
ClusterPointStyle
map_suite_silverlight_edition_sample_cluster_point_style.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In this project, you will see how to use a custom style, ClusterPointStyle for clustering various features into one. Sometimes, the map may have many features stacked on top of each other at high zoom levels making the map too busy and difficult to read. Clustering is a usefull technique in those situation making the map more readable. It groups together various features into one symbol with the count of all the features being labeled.
Decimal Degrees Formatting
map_suite_silverlight_edition_sample_decimal_degrees_formatting.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ The purpose of this project is to complete the static class DecimalDegreesHelper. This class offers functions to go to and from Decimal Degrees but it lacks the functions handling various formats such as Degrees Decimal Minutes and Degrees Minutes Decimal Seconds. Those formats can be output by different GPS devices and it is handy to know how to manipulate them and convert them to Decimal Degrees, the only format that can be input into a GIS or Mapping application.
Default ValueStyle
map_suite_wpf_edition_sample_default_valuestyle.jpg View Source
C# Download
Wpf \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In today’s Wpf project, we demonstrate the extensibility of ThinkGeo API by creating a custom Style. Inheriting from ValueStyle, we create a Default Value Style that handles the drawing of features that don’t have a value defined in the ValueStyle. Here we are using a point based layer with PointStyle. Note that the Default ValueStyle would also work with line and polygon based layers.
Displaying One-Way Streets
map_suite_silverlight_edition_sample_display_one_way_streets.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the Discussion Forum Post “Drawing one-way streets in the map”, we have a question on how to display an arrow on a street that is one way as Google Map does. In this project, we show the solution by creating a LineStyle specifically for that purpose. We take the shapefile “AustinWithOneWayRoad.shp” from the sample app “Route On One-Way Roads” of Map Suite Routing Extension to display the arrow according to the traffic direction on the one-way streets
Distance Line Style
map_suite_silverlight_edition_sample_distance_line_style.jpg View Source
C# Download
Web \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This Web project shows how to create a new style class CustomDistanceLineStyle inheriting from LineStyle class. You can pay attention to how the DrawCore function is override for a very specific need of style: displaying the distance label on each line segment making up a LineShape. In addition to the overriding of the DrawCore function, you will find useful some geometry functions such as GetPointOnLine to find the midpoint of a line segment and GetAngleFromTwoVertices to incline correctly the labels according to the orientation of each line segment. You will notice that the CustomDistanceLineStyle works for features made of LineShape and you will have to slightly modify to have it working with MultilineShape.
Doughnut Point Style
map_suite_silverlight_edition_sample_doughnut_point_style.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This project shows how to create a doughnut point style as this style is not offered by the MapSuite API. DonutPointStyle inherits from PointStyle and you will notice that in the overridden method DrawCore, no reference to any GDI + API is used. That means that this style is drawing system independent.
EditOverlay Styles
map_suite_silverlight_edition_sample_editoverlay_styles.jpg View Source
C# Download
Web \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In today’s Web project, we learn how to control the styles of the EditOverlay for both the default style and the editing style. In order to accomplish this, we write some javascript code. Look at the code in the “script” tag to see how we can control the fill color, the opacity, the border width etc of the features in the EditOverlay.
Feature Centric Style
map_suite_silverlight_edition_sample_feature_centric_style.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This project got inspired for looking at the sample “ClassBreakStyle” of How Do I demo apps. Using a ClassBreakStyle, the data is displayed based on what class each feature belongs to. Using a custom FeatureCentricStyle, each feature is displayed in relation to a central feature. In this example, it shows all the countries that have a comparable population to a reference country.
Flashing Point Style
map_suite_silverlight_edition_sample_flashing_point_style.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In this project, we explore how to create a point style that flashes. Here we take the example of a vehicle moving around based on GPS location and flashes when entering prohibited zones. I think that this project will inspire people working on building a vehicle tracking application. This project is a general solution for a Servicess edition. Notice that we are using two MapEngines with one only for drawing the flashing vehicle to avoid redrawing the other layers at each flashing.
Hybrid TextStyle
map_suite_silverlight_edition_sample_hybrid_textstyle.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This project is a follow up to the Discussion Forum post
http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6652/afv/topic/Default.aspx
In this project, we create a new Text Style combining word wrapping that we saw in the project
http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
Line Style With Increment
map_suite_desktop_edition_sample_line_style_with_increment.jpg View Source
C# Download
Desktop \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In today’s winforms desktop project, we expend on the functions of DistanceLineStyle shown on a previous sample, “Distance Line Style”. Here we show how to create a custom LineStyle for showing distance increment at a regular interval (every tenth kilometers). Having this LineStyle can be very handy when dealing with line network such as roads or railways.
Multiple Dot Density Styles
map_suite_wpf_desktop_edition_sample_multiple_dot_density_styles.jpg View Source
C# Download
Wpf \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ In this sample, we are looking in a little more detail at the DotDensityStyle. You can combine different DotDensityStyles on one FeatureLayer using different columns. Demographic data are usually well fit to be used with that type of style. Here each dot of a certain color represents 100,000 persons of the same age group by state. Using multiple DotDensityStyles, the dimension of age group demographics is added to the representation of population density. Note that the PointToValueRatio is used to set how many people a dot is going to represent. For example, if you want a dot to represent 100,000 persons, you set it to 0.00001 (1 / 100000). If you want it to be 500,000 persons, you set it to 0.000002 (1 / 500000).
MultiLine Labeling
map_suite_wpf_desktop_sample_multiline_labeling.jpg View Source
C# Download
Desktop \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ For labeling purpose, TextStyle has a property called LabelAllPolygonParts that will label all the parts making up a polygon based feature. Unfortunately, we don’t have an equivalent API for labeling all the parts of a line based feature. But thanks to the flexible framework of Map Suite, we show in this Wpf sample how easily you can expand the TextStyle class to allow this labeling capability. Look at the custom class MultiLinetextStyle and how DrawCore function is overridden to have the expected labeling behavior.
Projection Distance LineStyle
map_suite_silverlight_edition_sample_projection_distance_linestyle.jpg View Source
C# Download
Web \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This Web project is similar to the project “Distance Line Style”. Here we show how to use a projection of choice different from the projection used on the map. For example, you may have your map using Google map as a background. Google map uses Spherical Mercator projection which is not ideal for distance measurements, that is why using a more appropriate projection for distance measurement such as State Plane will give more accurate results. The CustomDistanceLineStyle inheriting from LIneStyle has the logic built in to have the distance calculated based on a projection of choice instead of the projection of the map.
Rotate Icon
map_suite_silverlight_edition_sample_rotate_icon.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the “How Do I” windows apps, there is sample “Efficiently Move A Plane Image” that shows a plane moving across the map from west to east along the Great Circle path. A flaw in this sample is that the plane is always shown flying in one direction regardless of the curve of the path.
Routing Styles
map_suite_silverlight_edition_sample_routing_styles.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ The API for the Routing extension product provides a class RoutingLayer. RoutingLayer is basically a convenient layer to have the features for routing being displayed in a default way. You can add the start, end point, the routes and it is going to display that nicely for you without much work on your side. While this is convenient, you may be in the situation when you want more control on the styles and have the whole flexibility that an InMemoryFeatureLayer gives you. In this project, we show how to display in InMemoryFeaturesLayers the start and end points, as well as the resulting route using the full power of InMemoryFeatureLayer such as zoom levels and custom styles.
Scaling Image Style
map_suite_silverlight_edition_sample_scaling_image_style.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This project presents a useful case where you want to have the icon representing a feature to be sized in proportion to the current scale. It is little bit similar to what we show in the project SizedPointStyle exept that the size of the symbol is based on the scale, not on some values specific to each feature. That explains why in the class ScalingImageStyle, the method GetRequiredColumnNames is not overriden. The whole drawing logic can be contained in DrawCore.
Scaling TextStyle
map_suite_silverlight_edition_sample_scaling_textstyle.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This project shows how to create a Style inheriting from TextStyle to have the label sizing according to the scale. You will see that the logic of scaling is basically the same as the on in the previous project “ScalingImageStyle” but applied to TextStyle.
Scaling TextStyle for Polygon
map_suite_services_edition_sample_scaling_textstyle_for_polygon.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the project “Scaling TextStyle”, we learned how to create a custom TextStyle to have the font size proportional to the scale while zooming in and out the map when labeling point based features. In the project “Scaling Image Style”, we learned basically the same thing but applied to an icon or an image. In today's project, we also learn how to create a scaling textStyle but for polygon features. Notice in the overridden DrawCore function how we calculate the font size based on the current and how we make sure no label overlapping exists by using the function CheckOverlapping of the base class before drawing the label for each part of the polygon.
Side View Icon
map_suite_silverlight_edition_sample_side_view_icon.jpg View Source
C# Download
Desktop \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This project is a little bit similar to the previous one Rotate Icon. It shows how to display correctly side view icons of moving vehicles. With top down view icons of vehicle, you simply rotate the icon according to the direction of the vehicle. But with side view icons of vehicle, it is a little bit trickier and you have to use a pair of icons. This project shows how to handle that and also how to calculate the direction of a vehicle based on the current GPS reading and the last one.
Sized Point Style
map_suite_silverlight_edition_sample_sized_point_style.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ Creating a Custom Style is a great way to encapsulate custom logic draw symbol based on some values. This project shows that using the concrete example world capitals. In this example, we draw capitals as circles with the size proportional to the population. We create the class SizedBasedPointStyle inheriting from PointStyle. We override the method DrawCore for the drawing logic. We also override the method GetRequiredColumnNamesCore to make sure we have the column for Population that will be used in DrawCore method to calculate the correct size of the circle for each feature.
Smooth Transparent Route
map_suite_silverlight_edition_sample_smooth_transparent_route.jpg View Source
C# Download
Desktop \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the Routing extension, the API GetRoute of the RoutingEngine returns a MultilineShape made of a collection of LineShape. By default, the MultilineShape has LineShapes for each two vertex line segment. The result in the displaying of the route using some transparency is a route that looks dotted and irregular. In this project, we show the trick to get one continuous LineShape which will show as smooth and regular. We recognized that the default result is not the most adequate in most cases and we will correct that for the next major release of the Routing extension. In the meantime, you can use that project to get the result that you want to display your routes.
Start End LineStyle
map_suite_silverlight_edition_sample_start_end_line_style.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ Today, we are looking at how to extent LineStyle to have a style for lines that shows the start and end points. This is useful to display line features with that custom LineStyle if you are mindful of the order it was digitized and you want to know the direction of the lines. This project is similar to previous ones where LineStyle is extended such as “One Way Streets” and “Distance Line Style”.
TextStyle for Multi Line
map_suite_silverlight_edition_sample_textstyle_for_multiline.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ If you are labeling features based on MulilineShapes, using the default TextStyle, only one line of the collection of lines making up the MultilineShape is going to be label. In today’s project, we show how to create a new class inheriting from TextStyle that will label all the lines of the MultilineShapes. That behavior is similar to the property LabelAllPolygonParts of DefaultTextStyle for polygons.
Time Based Point Style
map_suite_silverlight_edition_sample_time_based_pointstyle.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ This project shows how to create a custom style to display info based on some live data. Here we display world capital with a symbol for day or for night according to the local time. The method GetRequiredColumnNamesCore is overridden to make sure the column for the time zone is used. The method DrawCore is also overridden. It contains the logic to determine if a feature is within day time or night time according to the time zone column and the system time on the machine.
Time Line
map_suite_silverlight_edition_sample_time_line.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In this project, we learn another way to inherit from Style creating the class DateBasedStyle to display features according to some time values. Using a Time Line based on a track bar, the user can scroll back and forth on the time line to see what states were parts of the Union at any year.
ValueStyle with Countries
map_suite_silverlight_edition_sample_valuestyle_with_countries.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In today’s project, we revisit the ValueStyle class that is introduced in the “How Do I” sample app “Draw Features Based on Values”. In that sample app we show how to use the ValueStyle on a point based layer to display cities according to their population rank. In today’s Code Community project, we apply the ValueStyle to the polygon based countries layer (supplied with the sample apps). The countries layer has a column named “Color_map” with values from 1 to 8. Each number is assigned a color; that way the countries are displayed with 8 various colors on the map helping to distinguish them easily.
Weather Line Style
map_suite_wpf_desktop_edition_sample_weather_line_style.jpg View Source
C# Download
Wpf \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In this Wpf sample, we learn how to extend LineStyle class to create a style for representing weather fronts such as cold front, warm front and occluded front for your weather maps. To achieve that styling a regular LineStyle is used for the front line itself. For symbolizing the type of front an icon is used. Notice the two handy properties to give you more control: Spacing property to adjust the distance in screen coordinate between each symbol on the line and Side property to control on what side of the line front the symbols should appear. Of course, as you zoom in and out on the map the spacing between each symbol remain the same as it is set in screen coordinate.
WordWrapped TextStyle
map_suite_silverlight_edition_sample_wordwrapped_textstyle.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the Discussion Forum post “Display word-wrapped text”, there is a discussion on how to implement a TextStyle doing word wrapping. In this project, you will actually find a working implementation. Notice that by using the class WordWrappingTextStyle, word-wrapping is applied according the proportion of the size of the text to the size of the bounding box of the feature to label. This means that the label can be word-wrapped or not depending on the zoom level.
World Sized Image Style
map_suite_silverlight_edition_sample_world_sized_image_style.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ At the request of a client, today we have a project showing how to have an ImageStyle of real world dimension. A good example to show that is to use an image representing a cruise ship. Knowing that the ship is of 300 meters of length and 90 meters of width, we can use an image representing a ship and set those dimension to it. It will be drawn on the map always at those dimensions regardless of the zoom level. The logic used for this is very similar to what we saw in the project World Sized TextStyle but applied to images.
World Sized Text Style
map_suite_silverlight_edition_sample_world_sized_textstyle.jpg View Source
C# Download
Services \\ \\ Applies To: WindowsPhone \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In our Discussion Forum, we have a user asking for how to label text at world coordinates. For example, how to display a label at a size of 50 kilometers? Now, you can find in this project a custom TextStyle called WorldSizedTextStyle that does that. Whether your map is in Meters, Feet or Decimal Degrees, you can have the labels displayed at the desired size in any real world distance unit such as kilometers, meters, miles, feet etc.
map_suite_windows_phone_edition_styles_samples.1440040124.txt.gz · Last modified: 2015/09/10 09:51 (external edit)
