map_suite_windows_phone_edition_labeling_samples
Map Suite Windows Phone Edition Labeling Samples
Labeling based on size
MultiLine Labeling
Multiple Labels
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “ColumnName1[ColumnName2]…” and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
map_suite_windows_phone_edition_labeling_samples.1441876793.txt.gz · Last modified: 2015/09/10 09:19 by admin
