map_suite_webapi_topology
Map Suite WebAPI Topology
Video Overview
Overview
We are pleased to announce a new set of static Map Suite APIs relating to topology, along with an application to test topology rules. Topology is a critical function of a GIS application and we now have a great implementation of this feature. We have worked hard to ensure that we have included the most important cases along with an easy-to-use API. Below are a list of all of the cases we cover.
  • Lines End Point Must Be Covered By Points
  • Lines Must Be Covered By Boundary Of Polygons
  • Lines Must Be Covered By Feature Class Of Lines
  • Lines Must Be Larger Than Cluster Tolerance
  • Lines Must Be Single Part
  • Lines Must Not Have Dangles
  • Lines Must Not Have Pseudonodes
  • Lines Must Not Intersect Or Touch Interior
  • Lines Must Not Overlap With Lines
  • Lines Must Not Self Intersect
  • Lines Must Not Self Overlap
  • Points Must Be Covered By Boundary Of Polygons
  • Points Must Be Covered By EndPoint Of Lines
  • Points Must Be Covered By Lines
  • Points Must Be Properly Inside Polygons
  • Polygons Boundary Must Be Covered By Boundary Of Polygons
  • Polygons Boundary Must Be Covered By Lines
  • Polygons Must Be Covered By Feature Class Of Polygons
  • Polygons Must Be Covered By Polygons
  • Polygons Must Be Larger Than Cluster Tolerance
  • Polygons Must Contain Point
  • Polygons Must Cover Each Other
  • Polygons Must Not Have Gaps
  • Polygons Must Not Overlap With Polygons
The ends of lines in one feature must be covered by points in another feature.
Border
Lines in one feature must be covered by the boundaries of polygons in another feature.
Border
Lines in one feature class must be covered by lines in another feature.
Border
Cluster tolerance is the minimum distance between vertices of features. Vertices that fall within the cluster tolerance are defined as coincident and are snapped together.
Border
Lines within a feature must only have one part.
Border
The end of a line must touch any part of one other line or any part of itself within a feature.
Border
The end of a line cannot touch the end of only one other line within a feature. The end of a line can touch any part of itself.
Border
Lines can only touch at their ends and must not overlap each other within a feature.
Border
Border
Lines in one feature must not overlap any part of another line in another feature.
Border
Lines must not overlap any part of another line within a feature. Lines can touch, intersect, and overlap themselves.
Border
Lines must not cross or overlap themselves within a feature. Lines can touch themselves and touch, intersect, and overlap other lines.
Border
Lines must not overlap themselves within a feature. Lines can touch, intersect, and overlap lines in another feature.
Border
Points in one feature must touch boundaries of polygons from another feature.
Border
Points in one feature must be covered by the ends of lines in another feature.
Border
Points in one feature must be covered by lines in another feature.
Border
Points in one feature must be inside polygons of another feature.
Border
The boundaries of polygons in one feature must be covered by the boundaries of polygons in another feature.
Border
Polygon boundaries in one feature must be covered by the lines of another feature.
Border
The polygons in the first feature must be covered by the polygons of the second feature.
Border
Polygons in one feature must be covered by a single polygon from another feature.
Border
Border
Each polygon must contain exactly one point. Each point must fall within a polygon.
Border
All polygons in the first feature and all polygons in the second feature must cover each other.
Polygons must not have a void between them within a feature.
Polygons of the first feature must not overlap polygons of the second feature.
Topology
The topology sample makes it simple to test topology rules.
map_suite_webapi_topology.1450077354.txt.gz · Last modified: 2015/12/14 07:15 by tgwikiupdate
