map_suite_web_for_webforms_api
ThinkGeo.MapSuite.WebForms
ThinkGeo.MapSuite.Cogo
ThinkGeo.MapSuite.Drawing
  • DrawingFontStyles WindowsLinuxAndroidiOSMac
    This enumeration specifies the type of font style for drawing text.
  • DrawingGraphicsUnit WindowsLinuxAndroidiOSMac
    This enumeration represents the graphics unit.
  • DrawingLevel WindowsLinuxAndroidiOSMac
    This enumeration represents the drawing level used in the GeoCanvas.
  • DrawingLineCap WindowsLinuxAndroidiOSMac
  • DrawingLineJoin WindowsLinuxAndroidiOSMac
    This enumeration specifies how to join consecutive line or curve segments.
  • DrawingPenAlignment WindowsLinuxAndroidiOSMac
  • DrawingQuality WindowsLinuxAndroidiOSMac
    This enumeration specifies the drawing quality of the GeoCanvas.
  • GeoBrush WindowsLinuxAndroidiOSMac
  • GeoBrushes WindowsLinuxAndroidiOSMac
    Provides a collection of predefined GeoBrushes
  • GeoCanvas WindowsLinuxAndroidiOSMac
  • GeoColor WindowsLinuxAndroidiOSMac
  • GeoColors WindowsLinuxAndroidiOSMac
    This class is a collection of predefined colors
  • GeoDashCap WindowsLinuxAndroidiOSMac
  • GeoFont WindowsLinuxAndroidiOSMac
    This class represents a font that is used to label features on a GeoCanvas.
  • GeographicColors WindowsLinuxAndroidiOSMac
    This class is a convenient way to access a predefined set of geographic colors.
  • GeoHatchBrush WindowsLinuxAndroidiOSMac
    This class represents a brush that fills with various patterns.
  • GeoHatchStyle WindowsLinuxAndroidiOSMac
  • GeoLinearGradientBrush WindowsLinuxAndroidiOSMac
  • GeoLinearGradientDirection WindowsLinuxAndroidiOSMac
    Specifies the direction of a linear gradient.
  • GeoPen WindowsLinuxAndroidiOSMac
    This class represents a GeoPen, which is used to draw lines on a GeoCanvas.
  • GeoPens WindowsLinuxAndroidiOSMac
    Provides a collection of predefined GeoPens
  • GeoSolidBrush WindowsLinuxAndroidiOSMac
  • GeoTextureBrush WindowsLinuxAndroidiOSMac
  • GeoWrapMode WindowsLinuxAndroidiOSMac
  • LineDashStyle WindowsLinuxAndroidiOSMac
    This enumeration specifies the style of dashed lines drawn with a GeoPen object.
  • PenBrushDrawingOrder WindowsLinuxAndroidiOSMac
    This enumeration determines whether the brush or the pen draws first.
  • PlatformGeoCanvas WindowsLinuxAndroidiOSMac
    This class represents a canvas that is used to draw geographic shapes with GDI+.
  • RandomColorType WindowsLinuxAndroidiOSMac
    Defines values represent which kind of color will use for randomly.
  • SimpleColors WindowsLinuxAndroidiOSMac
    This class is a convenient way to access a predefined set of simple colors.
  • StandardColors WindowsLinuxAndroidiOSMac
    This class is a convenient way to access a predefined set of standard colors.
ThinkGeo.MapSuite.Jeffersonian
ThinkGeo.MapSuite.Layers
ThinkGeo.MapSuite.Portable
ThinkGeo.MapSuite.Serialize
ThinkGeo.MapSuite.Shapes
  • AreaBaseShape WindowsLinuxAndroidiOSMac
  • AreaUnit WindowsLinuxAndroidiOSMac
    Units describing various ways you can measure areas.
  • BaseShape WindowsLinuxAndroidiOSMac
    The abstract class from which area shapes, line shapes, and point shapes inherit from.
  • BufferCapType WindowsLinuxAndroidiOSMac
  • Conversion WindowsLinuxAndroidiOSMac
    This static class provides a conversion method to go to and from different units.
  • DecimalDegreesHelper WindowsLinuxAndroidiOSMac
  • DegreesMinutesSeconds WindowsLinuxAndroidiOSMac
    This structure represents a degrees, minutes and seconds value.
  • DistanceUnit WindowsLinuxAndroidiOSMac
    Units describing various ways you can measure lengths.
  • DrawingRectangle WindowsLinuxAndroidiOSMac
    This structure represents the drawing of a rectangle in screen coordinates.
  • DrawingRectangleF WindowsLinuxAndroidiOSMac
  • EllipseShape WindowsLinuxAndroidiOSMac
  • ExtentHelper WindowsLinuxAndroidiOSMac
    This static class exposes a number of helpful methods when dealing with extents.
  • Feature WindowsLinuxAndroidiOSMac
  • LineBaseShape WindowsLinuxAndroidiOSMac
  • LineShape WindowsLinuxAndroidiOSMac
  • MapResizeMode WindowsLinuxAndroidiOSMac
    The enumeration represents which mode will use for map resize.
  • MultilineShape WindowsLinuxAndroidiOSMac
  • MultipointShape WindowsLinuxAndroidiOSMac
    This class represents one or more point shapes.
  • MultipolygonShape WindowsLinuxAndroidiOSMac
  • PanDirection WindowsLinuxAndroidiOSMac
    This enumeration defines panning directions.
  • PointBaseShape WindowsLinuxAndroidiOSMac
  • PointShape WindowsLinuxAndroidiOSMac
  • PolygonShape WindowsLinuxAndroidiOSMac
  • Proj4Projection WindowsLinuxAndroidiOSMac
  • Projection WindowsLinuxAndroidiOSMac
  • RectangleShape WindowsLinuxAndroidiOSMac
  • ReturningColumnsType WindowsLinuxAndroidiOSMac
    This enumeration provides some options when querying a feature.
  • RingShape WindowsLinuxAndroidiOSMac
    This class represents a closed ring of points.
  • ScreenPoint WindowsLinuxAndroidiOSMac
  • ScreenPointF WindowsLinuxAndroidiOSMac
  • ShapeValidationMode WindowsLinuxAndroidiOSMac
    This enumeration describes the type of validation test to run on shapes.
  • ShapeValidationResult WindowsLinuxAndroidiOSMac
  • SimplificationType WindowsLinuxAndroidiOSMac
    Specifies which algorthm will be use to simplify.
  • StartingPoint WindowsLinuxAndroidiOSMac
    An enumeration describing the place to start on a line when doing certain operations.
  • Vertex WindowsLinuxAndroidiOSMac
  • WellKnownType WindowsLinuxAndroidiOSMac
    This describes a set of enumerations that list the valid types of geometries.
  • WkbByteOrder WindowsLinuxAndroidiOSMac
    This enumeration represents the byte order that well-known binary will be written in.
ThinkGeo.MapSuite.Styles
map_suite_web_for_webforms_api.1488789685.txt.gz · Last modified: 2017/03/06 08:41 by tgwikiupdate
