map_suite_web_for_webapi_features_bug_fixes_change_log
Map Suite Web For WebApi Features & Bug Fixes Change Log
Version 10.5.0
Release date: 04/01/2019
ThinkGeo.MapSuite.WebApi Namespace:
ThinkGeo.MapSuite Namespace:
  • Added support of Skia as the drawing engine to improve the performance.
  • Added support of semantic cartography schema – StyleJSON to design the map.
  • Added support of vector tile based *.MbTiles format.
  • Added support of ThinkGeoCloudRasterMapsLayer
  • Added support of high resolution for PlatformGeoCanvas, it mainly works for iOS edition
  • Enhanced to support parse special node in capability XML contains two spaces for WMTSLayer, generally Oracle export this type XML
  • Enhanced to support “ScaleFactor” property, it shows the high resolution value, it mainly works for iOS edition
  • Enhanced to support drawing halo pen dasharray on SkiaGeoCanvas
  • Enhanced to support both meter and decimal degree for NauticalCharts
  • Enhanced to support use ThinkGeoCloudRasterMapsLayer in iOS and Android edition
  • Fixed a bug that print google map to pdf tile unmatch
  • Fixed a bug that BuildingAreaStyle don't works follow design
  • Fixed a bug that OSM Buildings Url need get updated
  • Fixed a bug that some geotiff files looks jump when pan on map after set projection
  • Fixed a bug that text style don't works for wrapping lines in certain scenario
  • Fixed a bug that wrong boundary limit for Proj4Projection in certain scenario
  • Fixed a bug that the width or height value maybe equal zero when calling ToScreenCoordinate for GeoTiff
  • Fixed a bug that projection cannot handle parameter correct in certain scenario
  • Fixed a bug that PlatformGeocanvas throw format exception in certain scenario
  • Fixed a bug that GetDrawingExtent function loss precision in certain scenario
  • Fixed a bug that MapType is invalid when initializing ThinkGeoCloudRasterMapsLayer
  • Fixed bugs that some geotiff files cannot load correct
Version 10.4.0
Release date: 12/10/2018
  • Enhanced to use more accurate exception information
  • Added new overloading method for DrawText in GeoCanvas class
  • Enhanced to get better performance for data drawing when shape file contains many inner rings in polygon
  • Enhanced to support Esri srid input for Proj4Projection
  • Enhanced to support Esri coordinate system when create table for FileGeoDatabase
  • Enhanced to use more accurate exception information and exception type
  • Fixed a bug map throw null reference exception in certain scenario
  • Fixed a bug the Sqlite R Tree calculate different result in Windows and Linux
  • Fixed a bug some special invalid saturation and luminance values for GeoColor can pass our validation
  • Fixed a bug vector data won't render all shapes if the width is too big
  • Fixed a bug XyzFileBitmapTileCache lose cache ID in certain scenario
  • Fixed a bug GettingTileCache event won't be fired in correct step
  • Fixed a bug the overlays don't match when print to PDF
  • Fixed a bug white line shows for WMTSlayer
  • Fixed a bug exception is thrown when met invalid tile in WMTSlayer
  • Fixed a bug failed to load dll in FileGeoDatabase for asp.net scenario
  • Fixed a bug ECW render distorted image in special zoomlevel
  • Fixed a bug GeoTiff image jump in certain scenario
Version 10.3.0
Release date: 7/26/2018
  • Supported serializable for WebApi LayerOverlay
  • Fixed a bug that cache doesn't work for MsSqlFeatureLayer
Version 10.2.0
Release date: 10/27/2017
  • Fixed a bug where LayerOverlay throws exception when serializing with GeoSerializer
Version 10.1.0
Release date: 06/21/2017
Version 10.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Create new product center that is available to run on multi-platforms including Windows, Linux and macOS.
  • Support ECW files on Linux.
  • Support MrSid and JPEG2000 files on Linux.
  • Fixed a bug that LayerOverlay display overlapping labelings.
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
  • Added the new API SetWellKnownBinary(byte wkb) to Feature class to allow changing the WKB of the feature.
  • Improved the performance of method byte ShapeFile.ReadPolygon(byte dataBytes, int startIndex).
  • Added Leader Lines.
Version 8.0.0.150
First Release date: 07/11/2014
First Release - No Changes
map_suite_web_for_webapi_features_bug_fixes_change_log.1555643918.txt.gz · Last modified: 2019/04/19 03:18 by tgwikiupdate
