map_suite_web_for_webapi_features_bug_fixes_change_log
Map Suite Web For WebApi Features & Bug Fixes Change Log
Version 10.3.0
Release date: 7/26/2018
ThinkGeo.MapSuite.WebApi Namespace:
  • Fixed a bug that cache doesn't work with MsSqlFeatureLayer
  • Add the serializable for WebApi LayerOverlay
ThinkGeo.MapSuite Namespace:
Version 10.2.0
Release date: 10/27/2017
  • Fixed a bug where LayerOverlay throws exception when serializing with GeoSerializer
Version 10.1.0
Release date: 06/21/2017
Version 10.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Create new product center that is available to run on multi-platforms including Windows, Linux and macOS.
  • Support ECW files on Linux.
  • Support MrSid and JPEG2000 files on Linux.
  • Fixed a bug that LayerOverlay display overlapping labelings.
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
  • Added the new API SetWellKnownBinary(byte wkb) to Feature class to allow changing the WKB of the feature.
  • Improved the performance of method byte ShapeFile.ReadPolygon(byte dataBytes, int startIndex).
  • Added Leader Lines.
Version 8.0.0.150
First Release date: 07/11/2014
First Release - No Changes
map_suite_web_for_webapi_features_bug_fixes_change_log.1532513620.txt.gz · Last modified: 2018/07/25 10:13 by tgwikiupdate
