map_suite_web_for_webapi_features_bug_fixes_change_log
Map Suite Web For WebApi Features & Bug Fixes Change Log
Version 10.0.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Synchronize the Core APIs across all Map Suite product line.
  • Create new product center that is available to run on multi-platforms including Windows, Linux and macOS.
  • Allow to use Map Suite product without installer.
  • Simplified the license process.
  • Split the original MapSuite Core assembly by functionality. It allows users to embed required assemblies into their projects.
  • Support ECW files on Linux.
  • Support MrSid and JPEG2000 files on Linux.
  • Create a BareBone version package for Map Suite products to allow user to create app with minimum size.
  • Create a Standard version package for Map Suite products to transfer user’s existing project to 10.0 easily.
ThinkGeo.MapSuite.WebApi Namespace:
  • Fixed the overlapping issue.
  • Enhance file license.
ThinkGeo.MapSuite Namespace:
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
  • Added the new API SetWellKnownBinary(byte wkb) to Feature class to allow changing the WKB of the feature.
  • Improved the performance of method byte ShapeFile.ReadPolygon(byte dataBytes, int startIndex).
  • Added Leader Lines.
Version 8.0.0.150
First Release date: 07/11/2014
First Release - No Changes
map_suite_web_for_webapi_features_bug_fixes_change_log.1488791330.txt.gz · Last modified: 2017/03/06 09:08 by tgwikiupdate
